That is not true. Capacitance depends on diaphragm area and gap. Now sensitivity may be altered when changing the tension, by indirectly changing the damping, but also changing the frequency response.AusTex64 said:I understand that the capacitance and sensitivity is proportional to tension.
That's correct; however, increasing tension by itself does not change the nominal capacitance. Increasing diaphragm tension allows using higher polarization voltage (bias) before the diaphragm collapses. But it also changes the tuning, which may or may not be compensated by modifying the hole pattern of the backplate. I don't think it's doable by a DIYer.moamps said:Second one is capacitance when nominal DC polarization voltage is applied, and yes, this capacitance depends of the diaphragm tension and it is relevant value for all measurements and calculations.
