Just when I was about to ask some questions in the BM thread you opened this build thread! Fantastic! Thumbs up!
I'm in the process of working on dual channel TTx TG1.
I've stuffed boards except putting resistors that need calibrating. I've omitted hold control but have resistor in place of where it should go if basic compression works as it should and I plan to add it later. My build has no bypass and no input transformer - I permanently connected input to the board and jumpered bypass switch pads in permanent ON position. I have relay board near in/out connectors that will handle bypassing.
Now my issue is that both channels distort heavily in any mode. No compression at all! I've triple checked wiring (especially around HPF and Mode switches) and it seems okay. Meter is dead also.
Then I went to cross reference my build with schematics from Fester's TG1. I checked voltage on D2 and D4 input and it's around 13vdc. In Fester's that would be T_B. and T_C and they should be 10.6vdc.
Also, on Q1 emitter there's 6.8vdc (don't know what should expect here)
I had no more time to investigate further...
It's Murphy's law that you find your mistake just after asking for help!
I found what I did wrong - diodes D6 and D7 were orientated wrong. Now it's working almost as it should. I hear compression and limiting. THD mode is really distorted! I was expecting less distortion but it's cool.
I still have to go through calibration. Drivers for my oscilloscope are quirky and I have to fix that in order to go further.
But before I must say that I hear a lot of white(ish) noise when unit is compressing. Maybe it's too much compression that's pulling out this noise. I'll get back to that after I calibrate.
I'm still running my unit with unbalanced input. Is there anything I should change if I decide to leave it unbalanced? Maybe add an input pad?
If I decide to use 2:1 transformer what impedance should I go for?
Fripholm, during the hunt for error a BIG BIG help would be if you could publish pcb's silkscreen layer or hi-res photo of the board so we can all read component designations. Once the board is stuffed it's almost impossible to find certain components since they cover the silkscreen (yeah... I forgot to scan the board before stuffing... dohh me...)
Luka
