HerbertR
Re: [BUILD] fripholm's TG1 Zener Limiter boards - support thread
« Reply #580 on: November 26, 2020, 07:49:01 AM »
Outside
Right over is totally wrong
HerbertR
« Reply #581 on: November 26, 2020, 07:50:57 AM »
Inside
JMan
« Reply #582 on: November 26, 2020, 03:06:40 PM »
Congrats, Herbert!
Murdock
« Reply #583 on: December 18, 2020, 09:55:15 AM »
I don't know, if it was already covered. But what Impedance specs should the input Transformer have?
You recommend ratio of 2:1.
When we take the "normal" 600 Ohm input, the secondary Impedance is 150 ohms. Isn't that to low?
fripholm
« Reply #584 on: December 18, 2020, 11:32:12 AM »
You are right in that a transformer with a 2:1 winding ratio has a 4:1 impedance ratio. But in the case of an input transformer, the load that is connected across its secondary is 'reflected' with that ratio to the primary winding. It means that the input stage of the compressor with its input impedance of about 3 kOhms is 4 times that seen from the outside world through the transformer - about 12kOhms - which is in the ballpark of any line input.
'600 ohms' is just a meaningless rating for what a transformer is designed to work with - in this case, 'if it had a 150 ohms load across the secondary, the primary would see 600 ohms'.
Murdock
« Reply #585 on: December 19, 2020, 03:02:08 AM »
Thanks for the fast answer! The 3k Ohm information was what I needed. Thanks!
I know, what you mean with "600 Ohm is a meaningless rating". But it's not 100% true I think. It gives a clue about what inductance you can expect the transformer to have, which is important. Right?
fripholm
« Reply #586 on: December 19, 2020, 01:37:57 PM »
Absolutely! I meant 'meaningless' in the sense that the transformer can be used only at this particular impedance.
Murdock
« Reply #587 on: December 20, 2020, 10:21:26 AM »
Thanks! So it's safe to say, that a 600:150 Ohm transformer is not suitable for this circuit, right? 10k:2k5 would be better.
fripholm
« Reply #588 on: December 20, 2020, 12:30:24 PM »
No. I guess that was lost in translation.
Trying again: the label '600:150' does NOT mean that the transformer can only be used at this particular impedance of 600:150 ohms. Hence, it's 'meaningless' if you're trying to figure out at which circuit impedance the transformer will work. It may very well work fine.
I'm using Haufe transformers (labeled 90436) in my builds and I don't even know, what these were originally made for. When I asked Haufe about them, they also had no clue what those were - but as long as they sound fine, they are fine to me.
When I built my first 1073 clone with MIC/LINE switch, I had Carnhill 9045 (mic level) and 9046 (line level) transformers which I accidentally swapped without noticing. I somehow even managed to wire them backwards so that at least the ratios were correct. When I looked at the labels a year later, I realized my mistake and swapped them to their correct positions. Although they're clearly designed for different purposes, I didn't notice a difference in sound before or after the swap...
BerndVP
« Reply #589 on: December 26, 2020, 06:05:48 AM »
finally came to the point where I wired everything.
Now when playing sound thru the unit even in Bypass I'm getting distorted noise ?
When in active mode, nothing is happening on the VU
octavez
« Reply #590 on: January 03, 2021, 09:44:42 PM »
I'm wondering if the Carnhill VTB 9071 input transformer would be suitable instead of the VTB 9046 (not available at the moment)? They both seem to have fairly similar specs.
fripholm
« Reply #591 on: January 04, 2021, 12:41:40 PM »
The datasheet only mentions wiring options for 4:1 and 1:1 ratios but if you wire both the primary and secondary in parallel or both in series you should be getting 2:1 as well.
BerndVP
« Reply #592 on: January 04, 2021, 01:20:41 PM »
So, I rechecked all my wiring of my transfo's to my relays and to the BYP pins...
If I send audio thru the unit around +4dBu I need to set the input pot to max to get the VU showing a reduction of 4dB.
The unit in THD is directly distorting...
Any way I need to look at the unit ?
Also have one channel not passing audio thru it, but when bypassed it gives audio.
fripholm
« Reply #593 on: January 04, 2021, 04:13:23 PM »
The meters will not show anything useful before there is some clean audio passing from input to output. Did you do any of the audio calibration steps (not the meters)?
Please check one board at a time, block by block, step by step. Carefully read (and follow) the guide and this thread. For example, see this post on how to inject a test signal directly to the output stage to confirm that it's working correctly. Or check your voltages against the chart from this post.
octavez
« Reply #594 on: January 04, 2021, 06:49:25 PM »
That's what I thought too. It looks like the main difference is the optimal load impedances (seems higher on the VTB 9071). Would you recommend waiting on the VTB 9046 to be back in stock?
BerndVP
« Reply #595 on: January 05, 2021, 01:13:40 AM »
ok, will check this today,
On the audio pad that you give, is this directly coming from the audio interface or first thru the input transformer ?
fripholm
« Reply #596 on: January 05, 2021, 03:58:19 AM »
Yes, directly from the signal generator/interface. Start with a low signal level. There shouldn't be any DC on this pad that could harm an interface output. Measure it first against GND - to be safe.
Depends on how long you're willing to wait. If you're not, go for it   ;)
Note that I don't have any experience with either of them in the Zener but I'm pretty sure the 9071 will be fine.  8)
Last post September 30, 2019, 01:33:46 PM
by fripholm
Last post March 12, 2020, 11:54:45 AM
by masteringpole
Last post April 03, 2019, 11:58:21 AM
by dasnevestheo
Last post August 27, 2020, 05:33:00 PM
by Whoops
