First what do you want the scope for? What do you mean by entry level?
I suggest make a list of what you want it for now and what you might use it for in the future.
If for tube circuits check the CAT rating and you might want to buy higher than 10:1 probes rated for tube voltages.
Will you be using it with micro controllers? if so decoding options will be useful
2 channel 4 channel
what is the max frequencies
If you want FFTs I would check the EEV blog it has a youtube FFT video that was interesting
How does the sampling change when using more than one or two channels?
I have a tek 465 when I wanted a DSO I took a chance on the instek 2204E it is is OK so far I have not had the time to fully check it functions. Now I might pick a different brand I got the 2204E over a year ago and things change.
One reason I picked it is it has controls for each channel some have one vertical control and you need to select the channel you want to adjust, it was also about the price of 4 channel 200MHz scopes.
I still get annoyed with some DSOs when I first use them. I know what I want to do however different brands can have the buttons and menus set up differently. Some people stay with one brand because they know the buttons and menus
Other things to think about USB, RG45 and/or wifi, built in function generator, lab view etc. Is the software easy to use? is it tricky to update the firmware when updates are available? Do the probe autosense or do you need to set the channels up manually? What size screen and do you want a touch screen?
