Cqwet Dbdfte
- Joined
- Oct 2, 2023
- Messages
- 404
Besides a milliohm meter, or a FLIR scope, a high resolution voltmeter can be used to chase down shorts on a PCB, by using a stable low voltage supply, like 1V, current limited, then look for millivolt differences between conduction paths, lower voltages points to the problem.The tantalums on the 4XX series are all over the power supply rails, hundreds of them on a 485. They short to near zero ohms when they go. I ended up using a milliohm meter to zero in on the board to find the likely shorted one to minimize the work in pulling the various boards in the jam-packed cabinet. Wasn't unusual to find multiple shorted ones on the same scope, which means some probably went without power even applied.
