i have just restored a nice ampeg r12 guitar amp that had a burnt out secondary ht winding.
the transformer has been sent for rewinding to transformer equipment ltd. great work at less than a new transformer. totally recommend them for transformer repairs
now i am thinking it could be useful to put a fuse on the secondary, at least on the same ht tap that failed before
wondering the correct place to put the fuse. two fuses one on each side would probably be the safest option, but since the amp is cathode biased the ht winding is not shared by other taps, placing a single fuse between ht centre tap and ground could be enough ? this is actually like the classic Marshall JTM45 , and that amp is fixed bias instead. I have read in this case a single fuse from ht ct to ground is not entirely safe. would be great to hear your thoughts
