schrobbelbop
Hi guys!
I got a few issues left with my drip 670v3.
Trying to find a solution for the noise my HV choke makes in my 670 (dripv3).
(rattles when current increases/decreases more or less compression)
Sowter told me to make the resevoir cap (4,0uf) bigger. and add a parralel 0.5uf for hf.
or to open up the tranny and fill it with rubber, because sometimes the casing could
be resonating.. maybe the JJ tubes draw a bit more current then the original ones?
what about customizing attack times, i'd like to have an option for longer attack times?
what about inserting a highpass filter, where in the sidechain?
seems that the unit rolls off about 1.5 db from 60hz and down. drip told me to try
put a 1UF across the high windings of the control amp tranny. i cant follow the schematic
with the pcb very well, anyone knows where that is located?
last week i switched the unit off and fairly quick back on, that blew some fuses!
from the heaters and it's mains fuse. i replaced them and its fine again. Do
tubes draw crazy current when they're hot? it was kinda scary...
