Magnetic Metals pdf catalog?
fum
Seattle
Hey there,
Sadly, Magnetic Metals is getting out of the transformer laminations business.
I had a copy of their pdf laminations catalog on my hard drive, and unfortunately that hard drive catastrophically failed (as in, even the hard drive recovery doods who charge through the ass couldn't recover it).  They took the pdf down from their site.
Anyone have a pdf copy they could share?
Regards
ju
http://pdf.directindustry.com/pdf/magnetic-metals/transformer-lamination-catalog/21753-93215.html
Looks like You can at least view it here....... if this is what you are looking for.....
It is, but that view is lame, the pdf is hyperlinked, so you could jump around to specifics fairly readily.
I sent them an email, but alas no reply
Regards
ju
I did, yes.
Unfortunately, the pdf download was behind a login screen( you had to create an account to download it), so it doesn't have it catalog'd.
"Error, failed to download PDF document"
Hence my appeal to the audio geek collective  :p
But thank you for making me look at it again, if you go back a bit, they do have the data in non pdf format, which is useful!
if you just need dimensions you could go here,>
http://laminationspecialties.com/products.asp?productId=1
should have saved that file in the Meta, but no, i'm an idiot,  :-\
