I am re-designing a mic pre I have due to the fact that I wanted to eliminate the totem pole follower output. The rest of the mic pre is single ended, no negative feedback and I wanted to keep that topology through out as a I prefer that sound. The mic pre has a 225vdc B+ and all tubes are heated in series using a 50.4 vdc H+. That gives 12.6 vdc to the heaters of each of the 4 tubes and allows a phantom power supply without need a separate supply.
The way I have it set up right now is 1:10 input tranny > 7062 (e180cc) common cathode no negative feedback stage > coupling cap > stepped attenuator > 7062 (e180cc) common cathode no negative feedback stage > coupling cap > 5:1 (15k:600) output tranny. The former design uses 2 6072 stages and a third totem pole follower stage using a 12au7.
Although the 7062 is very close in mu to the 6072 and more current drive ability I cannot quite get the same output and voltage swing due to the beefy totem pole follower the original had. I want to add a third stage to better drive the output transformer. I plan to try a 12ab5, which is a lower voltage 6v6 with 12.6 volt heaters in a miniature Noval footprint. I plan to wire it as a triode in common cathode no feedback which should give 10 mu, 5000 gm, and 1965 ohms internal resistance. I believe this will be a nice fit but I only know enough to be dangerous. will it be too much for a mic pre output? Am I gonna blow up my converters with this thing?
