chrissugar
In the last few month was thinking more and more about a project.
A tape recorder emulation circuit.
I thought about building a complete high quality tape recorder electronics with all the correct equalisation caracteristics of the recording and playback electronics.
One method would be to use a transformer as a record/playback head with the correct inductance/impedance like in a real recorder.
The other method would be to use two real heads, and to couple them magnetically.
Yesterday I read at Prosoundweb a report about the Rupert Neve's new Legendary Audio "Masterpiece" Analog Mastering System.
The guy who tested it said that the thing really does what it say.
http://recforums.prosoundweb.com/index.php/t/4767/0
Here is the complete unit:
http://www.legendaryaudio.com/index.htm
You can download the pdf from:
http://www.legendaryaudio.com/MasterpceBro.pdf
It is mentioned that the tape emulation unit use a real magnetical circuit, but do not give more details if it is a transformer or two heads.
This made me think that this is a viable thing and it would be intersting to do some experiments.
I'm mostly interested to build something similar because I would like to have it as an aditional option in the mastering process (and why not tracking)
I supose it is not a simple thing but it can be done. Also I think that because there is no tape involved, the premagnetisation electronics is not needed.
So my questions would be adressed to the tape recorder Gurus. What impedances/inductances are common for some of the high quality tape recorders. I remenber that I found on the net a table with lots of data for various heads, but now I don't know where it is.
Also at what level heads start to saturate?
What electronics do you recomend for this project. I was thinking about some old tube Studer electronics. Any sugestions? Any schematics?
Also, do you think it is possible to emulate the two head assembly with a transformer with the right magnetic material and the right impedances/inductances?
It would be necessary to have a small gap to emulate it as close as possible?
Lets do some brainstorming.
chrissugar
chrissugar
