In hifi amps, for 'balanced' or push-pull stages, it is common to see 'balance' adjustment pots - it can be used in any of the plate, cathodes and even screens (for pentode).
You can see this done for example, in some of the 'vari-mu' classis .. the ua175, the rca ba25 etc.
It definately decreases thd in a stage, at least in some scenarios ... 'static' or quiescent conditions for sure ... maybe also under some actual operating conditions too!
So the question is how much of a good thing do we need ?
Surely, good hifi performance is benefitted by a balance adjust in the finals'. Same thing really for the driver ...
And to for the first stage.. So ... it is done, to have say 3 different balances
I have found it pretty easy to get quite tight balances under quiescent conditions at each of the stages.
The first stage and driver stage can each improve THD+N performance something like a couple of tenths of a % - quite significant. The finals' balance can improve approaching 0.5% of even 1% in some cases.
Adjusting across stages can also do noise cancellation ie. 'debalancing' the first stage can improve the end-end THD+N.
A nice benefit of adjusting balances at different points in a circuit, is that you can often get a 'sweet spot' in terms of representative spectra ... balancing can tailor to some degree the profile of THD achieved end-end.
Balancing takes time and has additional parts complexity .. and there is a diminishing rate of return!
One reason why 'vari-mu' limiters can be expensive to build and maintain - the balance of each stage is very important to achieve useable THD+N.
My el34 monoblocks use a 'plate balance' in the 6SN7 driver and individual 'bias pots' for balance at the grids of the EL34.
With careful adjustment, I could get the 1KHz THD+N at 0.13% at 30Wrms into 8ohm loads using 12dB global nfb.
At the end of the day, one can get pretty crazy about 'balance' .. thence going to 'constant current sources', long tailed pairs and bipolar HV supply rails ... to further force improved balance across the phases of stages ....
Judicious use of negative feedback(s) probably has more influence over performance than stage balance .. and the real fun is combining several stages of nfb ... like in the classic limiters like the ua175, rca ba25 etc.
The other thing to note ..... getting perfect balance at 'quiescent' operating conditions doesn't necessarily translate to similar figures in 'dynamic' operating conditions.
ie. more comprehensive testing is usually required to get to the core of things!
The last pair of finals I purchased were a pair of modern Tung Sol 7581a (super 6L6 type) ... 'matched' by the vendor ..... at the quite affordable end of the price range .... in my SE stereo 'spud' amp ... running +465V , 53mA each, the balance from Left,Right channels was +/- 0.5mA !
So out of the box, burned in a few hours and with no further adjustment, the finals were within 1mA of each other (quiescent and warmed-up). Of course, I have seen differences of up to several .. up to 5mA .. among unmatched 6L6s.
Something to note is of course, the measurement of parameters used in balancing adjustments - you can measure voltages easily enough, but most current measurments are derived from voltage measurements .. through some resistance ... which can be often be 5 .. 10% tolerance power resistors ... such as are used in tube amps.
You can put an ammeter inline with a circuit, and that is very accurate, but usually .. currents are measured indirectly as voltages and so can be a few % uncertainty ... 'real' balancing (high absolute acurracy) of voltages and currents in tubes can be very tricky business ...
For that reason, it is useful to get 'as close as you can' with voltage/current measurements, and then do 'final tweaks' while watching the spectrum with THD+N readings ..... at different points throughout the circuit.
_
