Jerry Garcia Wolf and Tiger Guitar Schematics
CJ
California
jus a throwdown on a jpg,
taken from here>
http://dozin.com/jers/guitars/wolf/schematic.htm
pickups changed over the years,  signal gets buffered by the jfet preamp, sent out to effects, returns to guitar so you can control the on/off from an on-board switch,  this keeps the effects sounding the same  regardless of master volume setting,
no out of phase sounds, just series/parallel on pickups, so humbucking takes place regardless.
kind of a large pixel count
    63.3 KB
Here is the Tiger guitar schematic,
differences between the Wolf are unity gain buffer instead of 10 dB gain preamp,  caps are wired above ground, humbucker split coil pickups only use one coil in single mode which means no humbucking action.
Also the effects loop jack has been simplified a bit (no contact switches).
you can google the circuit for the buffer and come up with various options,
taken from here>
http://dozin.com/jers/guitars/tiger/info.html
    66.4 KB
A bass player myself, so I never looked at the guitars, but because of the similarity, I figured they were made by Alembic as well. Apparently not, which explains why these do not have the low pass filters for tone controls, probably.
But that buffer might be the Alembic Stratoblaster
Slightly different schematic: http://www.generalguitargadgets.com/pdf/ggg_sbb_sc_i.pdf
single FET-thingie
Didnt Phil Lesh have a bass with each string on a different line output  ,in the old days the dead had central cluster type pa where each instrument had its own dedicated cabs vertically stacked , the PA was directly behind the band ,so they used  pairs of directional noise cancelling vocal mics to try and reduce spill .
I didnt see an effects loop in a guitar before ,  I prefer passive personally , but the idea of a switchable send buffered by the preamp I like , Id still want to be hitting the input stage on a tube amp directly with the pickups though .
The design of these guitars was very much under the influence of their SE, who, if he had his ways,  would have the instruments low-impedance and balanced, somewhat in continuity with Les Paul's Recording guitar. He probably didn't relish the idea of high-impedance pick-ups interacting with meters of cable and the non-linear Miller capacitance of a triode.
I worked with a band one time on their album , they had the big money record deal , no expense spared , they even brought in a vintage Les Paul recording on hire for the sessions , took a bit of work to get a sound out of the LPR and it still wast much use in the end. I'm more sound and electronics than any kind of guitar player , but I do personally prefer the passive ,
LPJr(Gordon Smith) ,Dimarzio Paf low output Humbucker bridge , Kent Armstrong p-90 neck is my set up , no coil taps, no out of phase .
Agreed; I've never heard a LPR sounding good. I heard Les Paul at the Iridium with an LPR once, and didn't like it, although he admittedly had gutted it of its low-impedance stuff.
I dabbed a little with on-board preamps and buffers. I was never convinced it made a huge difference. Today I always use a wireless system, which eliminates the interaction with the cables and input stage, but the advantages largely overcome the cons.
no out of phase .
When I was into on-board electronics, I figured out out-of-phase is a waste of time. It was all the rage at a time when people who should have known better described the in-between Strat sound (positions 2 & 4) as out-of-phase, which they aren't.
Gibson  L6  was another attempt to rewrite the book , a buddy of mine owns one ,horribly low output , best thing you can do is ,ditch the  rotary switch ,wire in a couple of regular Gibson pafs in LP config ,
Looking back , I think I used a passive Di in reverse to get the LPR 600ohm output back up to High(ish) Z ,allowing a few feet of cable between amp and DI so mains Tx wasnt causing interference .
Ron Wickersham was the guy behind the onboard preamp, and the first guy to put active electronics in an instrument, although Les Paul had a lot of gimmicks going on way before that,
Ron worked at Ampex before starting Alembic.
Alembic was probably kick started with LSD money from Owsley.
http://www.alembic.com/family/history.html
Jerry Garcia was the guy who wanted the effects loop installed.
Snippits from the book "Grateful Dead Gear" >
https://books.google.com/books/about/Grateful_Dead_Gear.html?id=SiTGAQR-W3YC
spinoffs from Alembic include Furman and Turner Guitars.
Ron >
    16.9 KB
As often, there's exaggeration in this assertion. According to Wickersham's wife, he started dabbing with on-board electronics in '69.
There are some examples of commercial products (not one-offs, experiments or prototypes) earlier than that.
From Wiki: "In 1967 Vox introduced a series of guitars that featured built-in effects such as Distortion (fuzz tone), Repeat Percussion (percussive tremolo), Treble/Bass Booster and a wah-wah operated by the heel of the picking hand pushing on a spring-loaded lever over the bridge. The Delta phantom style guitar and bass, the Starstream teardrop 6-string, and Constellation teardrop bass had such effects. "
Actually, the V251 "Guitorgan" came one year earlier.
I own a 1965 Supro Tremolectric that has on-board tremolo. Using a pulsing bulb (like the ones used in Xmas garlands) and a shunt photoresistor, it  hardly qualifies as electronic, though.
I would think there are several other examples.
