kosi
need some Freed 15k:600 OT info
« on: March 22, 2019, 04:26:58 AM »
Hi everybody,
what does M.W.V mean ? Never seen this before...
kindest regards
gyraf
Re: need some Freed 15k:600 OT info
« Reply #1 on: March 22, 2019, 11:30:57 AM »
maximum working voltage?
« Reply #2 on: March 22, 2019, 12:10:04 PM »
the difference between 3-4 and 5-6 is puzzling.
pucho812
« Reply #3 on: March 22, 2019, 01:25:52 PM »
freed.... maybe in here.
https://www.technicalaudio.com/pdf/Electronics_Catalog_Extracts/Freed_Transformer_Company_1960_REM_24.pdf
and according to google
MWV
Acronym   Definition
MWV   MeadWestVaco Corp (stock symbol)
MWV   Microsoft Windows Vista
MWV   Mineralölwirtschaftsverband eV
MWV   Mit Wirkung Vom (German: With Effect Of)
MWV   MovieWorks File (file extension)
MWV   Maximum Working Voltage
MWV   Mine Warfare Vessel
I am going to go with maximum working voltage.
« Last Edit: March 22, 2019, 01:30:35 PM by pucho812 »
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
rackmonkey
« Reply #4 on: March 22, 2019, 02:03:25 PM »
It’s certainly Max Working Voltage.  Edcor specifies its transformers similarly, with “input maximum voltage”.  Some of their transformers have a power level spec in watts too, but many just specify input max V.
Kind of an odd way to it. Historically, most manufacturers used units of power like watts, dBu or dBm.
Also, not the same as hipot rating.
Whether you think you can or you think you can't, you're probably right.
kosi
« Reply #5 on: March 30, 2019, 06:18:39 PM »
thanks everybody,
I will check them as output transformer for a cheap RCA BA2 clone with 6SN7
« Reply #6 on: March 30, 2019, 07:10:31 PM »
The stated frequency bandwith (300Hz - 3500Hz) seems a little narrow for modern studio use.  This transformer was probably intentend for a radio set. I am really interested in your results, maybe this iron can do better.
Last post January 27, 2008, 12:15:49 PM
by tony dB
Last post October 22, 2009, 11:16:46 AM
by skipwave
Last post January 14, 2014, 08:35:05 PM
by thomasdf
Last post February 27, 2013, 07:48:15 PM
by CJ
