user 37518
I was looking at the LM394 data sheet, and I found this straightforward instrumentation amp. It looks like a diff amp with 2 current sources at the emitter feeding a unity gain opamp in differential mode.
What I can see is that the 394 diff amp is not in the feedback path of the opamp (unlike a double balanced pre), so I dont know how low THD could be attained with this arrangement. Also the noise spec for the LM118 is far from stellar, so I would be using another opamp.
Can anyone explain why are the 500 ohm resistors there at the base of the input BJTs? stability?
Also, where does the 200K come from in the gain formula?
