Bloo LA2A VU Meter Bulbs
« on: June 09, 2019, 03:12:02 AM »
Hi All,
I got a Bloo LA2A recently, and I've been trying to figure out how (if ever) the VU meter was illuminated.
When I  open it up, I can't see any signs of a VU meter having ever been in there at all - but I might be missing something.
Here's a few pics of the meter assembly - any ideas on how I could get this lit up ?
https://i.ibb.co/4tnzYyL/20190530-123040.jpg
https://i.ibb.co/jHvz6WL/20190530-123046.jpg
https://i.ibb.co/LQVJM2M/20190530-123055.jpg
https://i.ibb.co/xFjvD8j/20190530-123324.jpg
Re: Bloo LA2A VU Meter Bulbs
« Reply #1 on: September 15, 2019, 06:31:57 AM »
Hi Guys !
Anyone got any ideas on how to light up this VU on this puppy ?
moamps
« Reply #2 on: September 15, 2019, 12:37:55 PM »
From the top outside?
« Reply #3 on: September 15, 2019, 12:57:23 PM »
yes indeed
mjrippe
« Reply #4 on: September 16, 2019, 05:51:30 PM »
I like warm white LEDs.  If they are clear, scuff the outer surface of the LED with 150 grit sandpaper for diffusion.  And yes, mount above the meter.
« Reply #5 on: September 16, 2019, 09:22:56 PM »
Any suggestions on where to tap the signal for that - i'm a bit apprehensive of working with this thing given the voltages floating around in there ?
mjrippe
« Reply #6 on: September 16, 2019, 10:37:17 PM »
Off the 6.3V filament voltage supply.  You will need a diode if they are not DC heaters in that design.  And you will need a current limiting resistor.
Phrazemaster
« Reply #7 on: September 17, 2019, 11:14:00 PM »
With just a diode wouldn’t it flash at 60hz?
** * Kablooie!
mjrippe
« Reply #8 on: September 19, 2019, 01:18:45 AM »
If it does, you won't see it.  Persistence of vision.
Phrazemaster
« Reply #9 on: September 19, 2019, 04:08:20 AM »
OK...it’s just I read a post on another site about this very thing and they said you can see the flashing. But maybe you’re right.
I’m doing a project right now and will need to solve this very thing; I was going to use a diode bridge but maybe that’s overkill.
Thx!
Mike
** * Kablooie!
mjrippe
« Reply #10 on: September 19, 2019, 11:39:44 AM »
Thx!
Mike
Hmmm, it would probably flicker on video but I have used this method and never noticed any flashing.
Phrazemaster
« Reply #11 on: September 19, 2019, 12:16:41 PM »
I’ll take your real world experience over some random post.
Thank you!
Mike
** * Kablooie!
Last post June 04, 2004, 11:18:15 AM
by SSLtech
Last post February 17, 2005, 08:37:11 AM
by SSLtech
Last post November 30, 2010, 06:29:52 AM
by MagnetoSound
Last post August 26, 2018, 11:09:01 AM
by 80hinhiding
