Sender
Presonus Eris E8
« on: August 13, 2019, 09:30:23 PM »
My friend's monitor is broken and I'm looking at it for him. It looks like one of the rectifiers on the power supply broke. I poked around a bit and didn't seen anything else wrong, however I'm hoping a schematic is kicking around somewhere so I can double check. Does anyone have an Eris E8 schematic they can share, or any other advice (maybe you fixed a similar issue with your E8)?
Khron
Re: Presonus Eris E8
« Reply #1 on: August 14, 2019, 04:22:26 AM »
List of symptoms? Some internal photos? Perhaps voltage measurements?
This is GroupDIY, remember? ;) Sitting around waiting for miracles... isn't the most productive option ;D
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
Sender
« Reply #2 on: August 15, 2019, 09:09:55 AM »
I was hoping the schematic would help with the DIY portion of it, it usually does!!!
When the monitors are switched on they immediately pop the input fuse. I cracked it open and didn't seen anything immediately obvious (no swelled caps, burnt components, etc.). It looks like there are two center-tapped secondaries that come off the transformer and go to rectifiers. The AC inputs of one of the rectifiers was shorted together so I'm going to replace that.
It seems a little odd that that is the only thing broken. I would expect something down stream to also be broken but I checked across all the big filter caps and LDOs and there weren't any shorts there.
I'll replace the rectifier and see how that changes things.
Khron
« Reply #3 on: August 15, 2019, 09:17:11 AM »
One thing to check might've been to disconnect the secondaries and see if it still popped fuses.
Although a "series bulb tester" might be a good way to save on fuses, for testing purposes.
Did you measure that "short" across the rectifier AC input with the transformer still connected, or...?
JohnRoberts
« Reply #4 on: August 15, 2019, 09:31:43 AM »
Check for a shorted reservoir cap... a bad cap can eat the diodes, while a shorted diode can trash the caps, so a bit of a chicken/egg thing.
Visit https://circularscience.com to hear what properly "cleared" drums sound like.
Sender
« Reply #5 on: August 15, 2019, 01:11:20 PM »
All measurements were made with the AC input transformer disconnected.
Khron
« Reply #6 on: August 15, 2019, 02:00:28 PM »
Then yes, at least two diodes in the respective bridge had turned into wires.
I'm guessing one (higher-voltage) secondary's for the power amps (or at least the woofer), and the other's for the opamps (and maybe tweeter amp)? Which one was shorted?
Sender
« Reply #7 on: August 19, 2019, 09:21:06 AM »
For those that were curious (and I'm sure so many were) there was a small ceramic cap across the diode bridge input that was shorted. Simply replacing that took care of the issue!
Khron
« Reply #8 on: August 19, 2019, 10:21:50 AM »
There you go then ;D
I've revived several laptops with that exact problem (shorted ceramic cap)...
Last post September 24, 2004, 05:23:35 PM
by Test Point
Last post April 22, 2008, 09:32:03 AM
by SSLtech
Last post November 11, 2008, 09:16:39 AM
by clintrubber
Last post January 10, 2012, 12:58:29 AM
by simonsez
