CurtZHP
I found an interesting little gadget. It appears to be a mic preamp mounted on an octal base for plugging into an octal relay socket.
Apparently, someone, somewhere built a modular mixer(?) and this was a spare. It's clearly labeled as a "mic amp," but there's really nothing more in the way of markings.
I took the cover off and found a little PCB in there, and I managed to trace out the circuit. I think I figured out where most of the connections go. A few of the eight pins aren't used at all. I think I figured out the input, the output, the power supply, and ground. But there's one pin that I can't quite figure out the purpose of. Here's a schematic.....
