5v333
Hi!
Im gonna make some drastical and hopefully last changes to my preamp.
Im gonna build another psu and change 6sn7 output tubes for 6V6 in Pentode connection.
Attached is part of the circuit , not showing the first tube and global feedback etc.
Since i havnt worked with pentodes before i wonder if this setup is acceptable.
Im mostly worried about the shared CCS on the cathodes and if anything can go wrong with the screens which will have separate regulated voltage.
the voltages and bias is a little bit of guess work with the help of average plate transfer curves and loadlines from plots with higher screen voltage and higher plate current.
