I use a very thick busbar, a 40W iron can only just solder onto it because it conducts so well.
The earth terminal at the IEC socket goes direct to the chassis via a short wire and a nut, bolt and washers.
The power supply earths are all joined together, there should of course be complete cancellation of ac within the power supply itself. So a bridge rectifier earth is joined to the first cap -ive and any centre taps on heaters or transformers. This goes to the far end of the busbar.
The amp grounds are connected along the rest of the busbar keeping each tube grounds as close as possible to avoid excessive loops. Finally, the other end of the busbar is connected to pin 1 and the chassis on the input socket.
I was nervous the first time I tried this but my V241-76 project shows that it works in practice.
Hope that is clearer.
