Hello,
I'm looking for info on four parts in particular:
43173
43174
43175
43176
The transistors have the Motorola logo, followed by "024," then the numbers I've listed above.
Any help or insight? I can't seem to find them on any cross-reference chart. The device in question is from around 1970.
Any leads?
analogguru
Re: Looking for information on old Motorola transistors. Datasheets?
« Reply #1 on: April 28, 2020, 10:02:41 PM »
These markings are no standard markings, probably they are custom markings.  You won't find a datasheet in a standard - even old - databook.
Where are they from ? any pictures ?
Whoops
« Reply #2 on: April 28, 2020, 11:21:44 PM »
I also vouch for those transistors having custom markings produced for a specific company.
whats the gear that uses them?
« Reply #3 on: April 28, 2020, 11:44:52 PM »
Here's a collage of images.
It's from a Ludwig Phase II Guitar Synthesizer, circa 1970.
Lots of mysteries about this unit. I've really struggled with it.
These transistors only are color-coded--there are four NPN-PNP pairs that have green (NPN) and yellow (PNP) paint on top.
There's another pair PNP-NPN pair where one has red paint on top and the other has blue. I read somewhere that sometimes Motorola color-coded their transistors this way to specify various properties in this era, but I don't know more than that.
I've also noticed, looking at these pictures, that there are some colored stripes down the back. Presumably these signify something, but I'm not sure what.
« Last Edit: April 29, 2020, 12:28:07 AM by soapfoot »
Whoops
« Reply #4 on: April 29, 2020, 12:28:01 AM »
What do the people athe Diystompboxes or Freestompboxes forum say about it?
did you see the following link?
maybe it's useful in case you need to get replacements transistors
http://www.geofex.com/Article_Folders/Ludwig_P2/Ludwig%20Phase%20II%20Clone.pdf
« Reply #5 on: April 29, 2020, 12:31:15 AM »
I'm well-acquainted with that link, but thanks for sharing it!
I tried registering for DIYstomboxes weeks ago, but I never got the activation email (not in spam folder either). I tried multiple times, and ultimately gave up (and just assumed that they must not be interested in new members).
In the document you reference, RG Keen specified 2N5551 for all NPN transistors in the unit. I'm certainly open to that, however I'd love to understand what the original parts were, and understand the degree to which that's an ideal substitute in each individual case.
Ideally, I'd love to find something as close to original as possible, and also just to understand exactly why certain parts (presumably hFE grades) were selected for particular locations.
My goal is to get this performing as close to original as possible (even more so than "as close to optimal as possible," if that makes sense).
« Last Edit: April 29, 2020, 12:38:38 AM by soapfoot »
Blue Jinn
« Reply #6 on: April 29, 2020, 05:41:25 PM »
OT but I had trouble registering at DIYStompboxes  as well.
not my thing. I am here just to unbalance the equation --pucho812
 http://www.bluejinn.org
« Reply #7 on: April 29, 2020, 05:52:11 PM »
I gathered some data today and I thought I'd share it here in case anyone is doing a search with a similar issue in the future.
Turns out the transistors I was concerned about were okay, and in order to verify that, I removed them all and measured them with a simple transistor tester. In the process, I recorded my data so that I could share it here.
The one marked 43173 (painted green on top) is a simple NPN bipolar junction transistor, There were four examples of this, with hFE between 164-206 and Vf between 832-846.
The one marked 43174 (yellow paint) is the PNP partner to the above, with hFE between 141-263 and Vf between 770-839
The one marked 43175 (blue paint) is an NPN bipolar junction transistor with hFE of 421 and a Vf of 764
The one marked 43176 (red paint) is the PNP partner to the above with hFE of 268 and Vf of 783,
Fortunately, I won't be needing to chase these down at the moment, so I'll consider this one closed. Thanks for looking!
Whoops
« Reply #8 on: April 29, 2020, 08:29:37 PM »
I registered there many years ago and had no problems.
But lately since the covid lockdowns I had problems in registering in a different number of forums, probably due to problems in maintenance at this point.
Anyway, that forum is useful but I much prefer the Freestompboxes forum
PRR
« Reply #9 on: April 29, 2020, 11:04:16 PM »
Like ALLLLL "DIY" forums, they are suddenly rich with people who Joined in March or April 2020. Obviously many are getting in. Aron may be a little backed-up... but must be approving many members.
JohnRoberts
« Reply #10 on: April 30, 2020, 09:47:07 AM »
Those may be house numbers for a large manufacturer...
Peavey used a number of motorola TO3s, but our house numbers started with 704xxxxx as I recall from decades ago.  As I recall they were popular motorola parts just specified tighter for some useful parameters.
Cancel the "cancel culture", do not participate in mob hatred.
« Reply #11 on: April 30, 2020, 09:59:19 AM »
Thanks, John--that definitely seems to be the case here.
There are also several National Semiconductor transistors in this unit that also have nonsense part numbers--and they're also all six digit numbers starting with "43."
JohnRoberts
« Reply #12 on: April 30, 2020, 11:26:06 AM »
Most mainframe MRPS (material resources planning system) inventory software used 8 digit part numbers. The first two or three digits defined the general type of component. Often production ICs have additional 4 digit markings that refer to year and week of manufacture.
mjrippe
« Reply #13 on: April 30, 2020, 12:51:21 PM »
Thank you John, that is great info to have.  I see a lot of mfg part numbers and that helps to make some sense of them.
« Reply #14 on: April 30, 2020, 01:35:47 PM »
Although this unit was marketed by Ludwig, the circuit board art seems to have the old Electro-Voice logo. Perhaps they manufactured it, and the in-house part numbers are theirs?
Audio1Man
« Reply #15 on: April 30, 2020, 06:47:20 PM »
Hi soapfoot
As a mfg you can go to ON,RCA, TI  or other semi mfg and buy a selected  2N3055 or other standard part with special specs and they assign an internal HOUSE NUMBER for you. I did this @Acoustic Control, BGW, and several other places  just like John did @ Peavey.
Duke
Last post February 05, 2005, 05:17:36 PM
by
Last post October 28, 2009, 10:41:35 PM
by Freq Band
Last post May 17, 2016, 12:34:45 AM
by mhbunch
Last post May 24, 2018, 02:07:17 AM
by soldermonkey
