valco
Airpax / Stancor Military grade transformers
« on: May 17, 2020, 03:39:03 PM »
Hi !
I recently got my hands on a bunch of these Airpax transformers from an old storage of surplus equipment from the army , but I haven´t been able to figure out what kind of transformer this is yet.  Is it a microphone transformer or something for some sort of radio equipment?
The transformers are labeled with Airpax AT- 601 821616 and a few that are similar and with similar numbering are named Stancor. They are also 8 pin
I´ve found these pages that i think is describing the transformer , but i can´t figure out what they are for and what the input ohm are and what the pin out are.
https://www.asap-distribution.com/nsn/nsn-parts/5950006923126/
https://www.asap-distribution.com/nsn/rfq/unisys-corp/5950006923126/821616/
https://www.parttarget.com/5950-00-692-3126_5950006923126_821616.html/-FD7C07EC-0909-4D98-A5F4-6F221325C10B
Does anyone have knowledge of these kind of transformers ?
valco
Re: Airpax / Stancor Military grade transformers
« Reply #1 on: May 17, 2020, 03:39:50 PM »
Stancore
valco
« Reply #2 on: May 17, 2020, 03:40:29 PM »
Pin out
squarewave
« Reply #3 on: May 17, 2020, 05:27:08 PM »
Measure DC resistance between each pins and find the ones that have continuity. That will tell you which are windings and which are just shields or the case or whatever. Once you identify the windings, put some AC in and see what you get out. Measuring impedance is a little harder but with DCR and a list of windings you can probably get some idea as to what they are.
valco
« Reply #4 on: May 19, 2020, 11:54:02 AM »
I sent signal thru on pin 1 and 2 and got them in return on 8 and 7 . Did the same on 3 +4 and got them out on 5 and 6 .
Then i sent a signal that measured 0,025 vac and got it out on the other side 0,065 vac , so if my calculations are right its a 1:3 transformer.
valco
« Reply #5 on: May 19, 2020, 12:00:10 PM »
Can they be used as microphone transformers ? or is the ratio too low ?
« Reply #6 on: May 19, 2020, 02:00:03 PM »
1:3 is fine for a semiconductor mic pre but too low for a tube one.
valco
« Reply #7 on: May 19, 2020, 04:18:52 PM »
Do you mean a electret mic ? I´ve never heard of a semiconductor mic
scott2000
« Reply #8 on: May 19, 2020, 04:34:45 PM »
Mic Pre
squarewave
« Reply #9 on: May 19, 2020, 04:54:56 PM »
Those could just be different taps. You need to start with basic contitunity measurements using a digital multi-meter. Draw a picture with DC resistance between each pin and post it.
valco
« Reply #10 on: May 20, 2020, 05:36:08 AM »
Mic Pre
My bad. I totally misread it.
Last post July 05, 2005, 07:57:38 PM
by skrasms
Last post May 17, 2019, 02:43:48 AM
by CJ
Last post September 24, 2019, 03:38:24 AM
by duende
Last post May 14, 2020, 02:39:06 PM
by Conviction
