Hooking up Hammond M3 to Leslie 142/122
rockinrob86
Tampa, FL
I have a Hammond M3 I have previously modified to pad the speaker output into an attenuator pot and finally to a 1/4" unbalanced out.  Was using this into a neo-ventilator (worked and sounded great!), but now I am graduating to a real Leslie 142!
I was planning on building the following schematic, with a Jensen JT11 FLCF.  I'm wondering if I just need to tie connection 4 on the primary to ground, and 1 to tip on the unbalanced jack?  Is this the best way to do this?
I would also like to be able to plug in guitars, reamp line level signals, etc.  I'm considering building a tube preamp and I could wire that like a typical preamp with an output transformer into the stock balanced circuit shown below.  Maybe it would be best to build this into a box with an input for my switch, a TS output for unbalanced and an XLR for balanced (know I could only use one input at a time), along with the power jack.  Then I wouldn't be tied to the organ.
Connecting an unbalanced source to a balanced input usually works. The transformer is good at minimizing ground loops. What kind of signal do you want to connect to the unbalanced jack?
What is the question?  :)
haha, yea reading back this wasn't the clearest.
I need to connect my unbalanced hammond to the leslie.  I would also like to plug guitars in on occasion, along with anything else including reamping tracks.
I was asking about how to/if I should wire the above transformer in the schematic to interface with unbalanced signals, and if this was ok.
Now I realized I can use an amp attenuator I have with a balanced line out (for guitars) and my studio interface can feed line out balanced, so I think I am going to build the above schematic stock.  I can either plug the hammond into my powered DI for acoustic guitar stuff, or option 2 is connect a transformer at the organ to convert the unbalanced signal to balanced.  I may need to redo the attenuation to increase the voltage some for this option.
But I think this solves the issue.  I thought it wasn't good practice to just plug in an unbalanced signal to a balanced input?  I guess I can try and see how the organ sounds this way.  If it doesn't matter then I don't need the DI/transformer!
It is ok, but beware that the amp is not very sensitive and you need quite a high level there. Guitar level is certainly too weak.
This won't work for two reasons.
The Leslie needs a floating signal in order to receive the rotation control voltage.
The Leslie amp cannot deliver full power with only one leg active.
