R rbuskov Well-known member Joined Apr 5, 2019 Messages 77 Jun 30, 2020 #1 Can anyone suggest a good replacement for the Haufe T4344/90485 input transformer? I would prefer something standard rather than custom made. The data sheet can be found here .
jensenmann Well-known member Joined Oct 10, 2004 Messages 2,859 Location Karlsruhe, Germany Jul 3, 2020 #2 Linking to kubarth.com doesn´t work. Do you need a mechanically identical replacement (e.g. for mounting it in the original way)? What circuit is it intended for?
R rbuskov Well-known member Joined Apr 5, 2019 Messages 77 Jul 12, 2020 #3 jensenmann said: Do you need a mechanically identical replacement (e.g. for mounting it in the original way)? What circuit is it intended for? Click to expand... It's for a Neumann W492 clone - does not have to be mechanically identical.
jensenmann Well-known member Joined Oct 10, 2004 Messages 2,859 Location Karlsruhe, Germany Jul 13, 2020 #4 Are you sure that it needs to be 2:1 stepdown? If not any 10k:10k line input transformer which can handle levels upto 21dBu is fine.
