musika
Help Needed for Allen & Heath Quasi mixer
« on: July 26, 2020, 01:17:24 PM »
I'm recapping a 22X2 Allen & Heath Quasi mixer from 1973 and want to implement a bypass switch so that the signal will pass from the mic preamp to the output busses.  Can someone help with design (where the switch goes) and type of switch needed?  I am including the schematics that I think are relevant and a pencil drawing of where I think the switch should be placed.  I would also like to be able to set up a test ( I do not have lots of test gear) to insure each channel strip works prior to reinstalling due to the fact that the busses are hard wired.  So any advice on this would be great too.
« Last Edit: July 26, 2020, 01:47:50 PM by musika »
musika
Re: Help Needed for Allen & Heath Quasi mixer
« Reply #1 on: July 26, 2020, 01:18:11 PM »
photo #2
musika
« Reply #2 on: July 26, 2020, 01:18:43 PM »
photo #3
musika
« Reply #3 on: July 26, 2020, 01:19:57 PM »
photo #4
musika
« Reply #4 on: July 26, 2020, 01:21:34 PM »
photo #5
musika
« Reply #5 on: July 26, 2020, 01:28:06 PM »
photo #6
JohnRoberts
« Reply #6 on: July 26, 2020, 02:47:29 PM »
That sketch looks you are connecting the bypass to a power supply pin?
Note:The Baxandall tone control stage is inverting so bypassing around that tone control will result in a polarity inversion... This could be audible in some cases...
PS: They spelled bus wrong, but lots of people did back then..
Don't only half-ass tune your drums. Visit https://circularscience.com to hear what properly "cleared" drums sound like.
musika
« Reply #7 on: July 26, 2020, 04:19:33 PM »
Should have left that out, since it was just a guess...
musika
« Reply #8 on: July 26, 2020, 04:35:52 PM »
They made a two versions of this thing back then, a 2 and 4 output.  The 4 out had a toggle added to permit switching.  Since this particular mixer was a 2 bus version, the holes were already drilled through the frame and face plate but no switch included, and so I was looking at bypassing some circuitry that could help overall noise from 22 channels - also considered a channel mute (maybe this would be a better solution).
cyrano
« Reply #9 on: July 26, 2020, 06:43:03 PM »
Had me fooled for a second too...
It's an audio path, directly connected to the bus, with a somewhat confusing name: fader app? supply. No DC power there.
Why is it people love to believe and hate to know?
JohnRoberts
« Reply #10 on: July 27, 2020, 11:58:43 AM »
OK you will still get a polarity inversion bypassing the inverting tone control.
squarewave
« Reply #11 on: July 27, 2020, 02:04:08 PM »
Uh, that's "fader amp supply" and it's definitely DC power alright.
MA1 output has DC bias. So whatever you bypass needs to be into a coupling cap. Maybe break the conn between the 47u and the collector of the transistor and then source from MA1. Note that you can just leave the feed from MA1 into the bax. Or you can break before the 10u of the second stage transistor. That would bypass the fader too but you would loose the feed for the F/B bus.
But I'm not sure how much that's going to improve noise. If you have a noise issue, you should diagnose that separately. There are probably other things that you could do that would make a bigger difference. In particular, the 220K pot makes for a pretty high source impedance. I wonder if there's a high gain NPN that has good noise performance with a high source impedance.
Or, a slightly crazier idea would be to put a JFET follower with a series resistor to match the OSI of the BC169. That might seem like a drastic measure but the key to low noise is low impedance so it might just be a win in this particular case. And it's like 3 parts so you could probably finagle it onto the board without making too much of a mess.
Another thing that would probably make a measurable difference is changing the supply for an SMPS with RLC filter.
musika
« Reply #12 on: August 06, 2020, 02:06:10 PM »
Thanks for pointing this impedance issue out.  When I looked further into the preamp components compared to my Mod2 ( which was 3 years later), they used  a 47K log pot for preamp gain.  All other amp components are pretty much identical.  Unfortunately I do not have any good way to compare - just my ears - and I have the Quasi torn apart at the moment.  Anyways thanks for pointing this out!
I also noticed a braided shield added to the Mod2 version on the transformer secondary.  Photo included.  Additionally ground from tranny soldered to the case of gain pot.
« Last Edit: August 06, 2020, 02:31:22 PM by musika »
squarewave
« Reply #13 on: August 06, 2020, 02:55:12 PM »
That load has to match the transformer secondary. So the transformer would have to be different or maybe wired in parallel instead of series. So be careful or your mic Z will drop 4x.
musika
« Reply #14 on: August 07, 2020, 10:44:41 AM »
I believe you are correct.  Closer look at the two documents (one for the MOD2 and Quasi) shows two different transformers.  Sowter 3379 used in the Quasi. I have written to them asking for documentation for this transformer and will post to the TD when I receive an answer.  Thanks for the info on the preamp!
musika
« Reply #15 on: August 07, 2020, 10:48:23 AM »
Block Diagram showing 3379 transformer.
musika
« Reply #16 on: August 11, 2020, 09:08:13 AM »
Searching the Sowter website, I found the specs that they published for this 3379 transformer.  It shows 200 ohm primary and 7.2K ohm secondary.  Turns ratio 1:6.
Notes show that this may have been originally designed for a company called Sound Techniques.
https://www.sowter.co.uk/archive/proaudio.htm
Last post June 07, 2006, 11:21:02 PM
by gar381
Last post February 18, 2008, 09:33:34 PM
by BR
Last post April 18, 2010, 06:49:32 AM
by doulos24
Last post October 09, 2012, 08:14:39 PM
by 3phase
