pucho812
Fully differential eq circuits?
« on: August 11, 2020, 03:26:16 PM »
Are there any eq’s out there that are a fully differential circuit?
Is it too costly to do?
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
Gold
Re: Fully differential eq circuits?
« Reply #1 on: August 11, 2020, 03:29:12 PM »
ADT V700 series. They are very expensive. https://www.adt-audio.com/Audio_Modules/Audio_Modules_V700.html
pucho812
« Reply #2 on: August 11, 2020, 06:09:06 PM »
Well one of the things that caught my attention in the aspen pitman interview was how he talked about fully differential circuits and  how it improved audio and why.  was wondering why more companies didn't do that.
Gold
« Reply #3 on: August 11, 2020, 06:22:41 PM »
I’ve never heard any of those modules. I’ve never known or heard of anyone using them. A search at the purple place brings up basically nothing.  I’ve heard of people using the Toolmod series.
That said they are very interesting.  There are some features that aren’t available anywhere else. The designer obviously put a lot of thought into them. Maybe if the modules were in 19” rack units they would be more popular. Spending $50K on a 5RU module system isn’t how most would allocate funds.
Ricardus
« Reply #4 on: August 11, 2020, 10:51:57 PM »
I just noticed they do a large format recording console, too. These guys are maniacs.
Audio mastering for hire..
pucho812
« Reply #5 on: August 11, 2020, 11:40:47 PM »
I am purely focused on the idea of fully differential. Not interested in buying them. But wanted to see who is doing it
« Reply #6 on: August 12, 2020, 12:07:05 AM »
RCA did it in some obscure passive filter sets in the 1930’s.   Balanced H types.
Maybe interesting is the idea of driving an EQ differentially rather than single ended.
pucho812
« Reply #7 on: August 12, 2020, 12:38:24 AM »
That too. Imagine a channel strip that is pre and eq and fully differential drop top to bottom vs just at the I/O
shabtek
« Reply #8 on: August 12, 2020, 08:30:56 AM »
What benefit justifies the additional complexity of parts matching ?
Differential drive  with tuned shunts would not need matching .
What order filter is that?
Cascaded and ganged stages will be needed for steeper boost cut.
« Last Edit: August 12, 2020, 08:38:51 AM by shabtek »
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
abbey road d enfer
« Reply #9 on: August 13, 2020, 03:07:45 AM »
Passive EQ's support differential implementation. It's more costly, since the series components have to be duplicated, but not the shunt elements. It can make sense, if it saves input/output xfmrs.
Active filters do not lend themselves easily to differential implementation. There are some examples in telecoms and instrumentation, probably resulting from transformation of passive filters into active ones.
I believe Aspen Pittman was referring to certain aspects of circuit implementation that benefit from differential path, such as distortion cancellation, noise rejection; there are good examples of differential circuitry in A/D and D/A converters, but I don't think there is one definite example of differential EQ's that make sense.
However,
jensenmann
« Reply #10 on: August 14, 2020, 11:09:11 AM »
I know several mastering engineers using  ADT V700 gear. Each of them is full of praises.
In my dayjob I use one of their 5MT consoles and racks full of their Toolmod gear. I can highly recommend all of their gear. There´s not one single piece amongst which is less than stellar.
Jens
Quote from: PRR
The tubes of course don't care what frequency they distort
Gold
« Reply #11 on: August 14, 2020, 12:02:26 PM »
It seems ADT mostly serves the German language market. It’s rare to see it in the US.  There is not much gear  I have any desire     to check out. The V700 series is an exception.
Last post August 31, 2005, 05:43:02 PM
by bcarso
Last post July 14, 2018, 03:33:12 AM
by ruffrecords
Last post May 30, 2009, 08:01:09 PM
by clintrubber
fully differential operational amplifier
Started by reanimatorstudio « 1 2 » Drawing Board
Last post April 28, 2012, 06:00:05 PM
by Twenty Log
