Rode K2 Rear Capsule not working
« on: January 05, 2021, 04:15:40 PM »
Hi all I received a Rode K2 from a friend and the rear capsule isn't working. That is there is no change in the rear capsule's output regardless of where the pattern select is on the the power supply, the front capsule does change slightly and as expected (and sounds great). I attempted replacing the capsule with a Dachman Audio C12 clone and have the same issue, I reversed the wiring of the dachman and confirmed both capsules are working.
Does anyone know what the voltages are suppose to be on the mic cable and what the pinout corresponds to? I haven't been able to locate any schematics for the power supply, and only a hand drawn version of the mic's circuit.
Any suggestions of what to try next? I'm talented at soldering and following directions but I'm still very much learning troubleshooting and engineering.
Khron
Re: Rode K2 Rear Capsule not working
« Reply #1 on: January 05, 2021, 07:04:09 PM »
Cold / broken solder joint, or faulty resistor(s) in the rear diaphragm polarization circuit?
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
« Reply #2 on: January 06, 2021, 11:38:03 AM »
That's kinda what I'm thinking but I'm not sure what part of the circuit that is, the labelling is vague on the PCB's and I'm still at an electronics 101 level when it comes to following a circuit, especially without schematics.
Ricardus
« Reply #3 on: January 06, 2021, 11:40:59 AM »
So it's basically always in Omni?
Audio mastering for hire..
« Reply #4 on: January 06, 2021, 12:34:21 PM »
It's basically always in Cardioid, the front capsule has a slightly narrower pickup pattern when I change it to figure 8 on the power supply, as it should. but at no point when sweeping from omni to figure 8 does the rear capsule pass sound. As I said in my original post, I tested the capsule and both sides are functional, so it's something to do with the circuitry in the K2
Gus
« Reply #5 on: January 07, 2021, 06:47:58 PM »
Look at the polarity of the supply and how the circuit is designed.
You have the beginning of your answer in your posts
Only cardiod and nothing else means the back is not getting a variable voltage. Why it is not getting it is what you need to trace.
Have you seen this?
https://groupdiy.com/index.php?topic=30971.msg375974#msg375974
Last post May 30, 2006, 12:02:09 AM
by edanderson
Last post November 20, 2008, 04:44:33 PM
by plumsolly
Last post December 22, 2008, 07:57:37 AM
by evil grill
Last post April 08, 2018, 03:28:01 PM
by mata_haze
