Val_r
This is the schematic diagram of a headphone amplifier I would like to build. It was taken from the web, originally designed for 10 paralleled 5687 tubes, with -200V bias and -13V on cathodes and 400Vpp drive. I have just adapted it for a single 6080WC with the 2 sections paralleled, to get an output impedance of about 100 ohms.
Not sure on the correct bias and drive (actually -120V, -152 according to the -32V cathodes, and 240Vpp drive).
Probably the drive needed is much less, allowing to use only 1 section of the 6CG7 (1 section per channel), instead of the actual cascade topology.
Need help. Any advice?
Val
:roll:
Val
:roll:
