Cascading two pots like you show does not result in better resolution.
There are several possible solutions. A simple one consists in putiing in series with the coarse pot a fine pot. Using two identical value pots will give about 6dB range for the fine pot. However, teh tapers should probably not be identical. If the coarse pot is a log taper, the fine pot should be linear or reverse-log.
Another possibility is cascading two identical pots, but adding a padding resistor at the bottom. Making this resistor eaqual to the pot value would give you the same 6dB range.
Thanks everybody for your answers !
but I think i was not clear enough with my questions (sorry for this)
I am NOT looking for a better resolution . but more like this exemple. let me trying to explain it better
Let’s say I have one pot at the input . 10K LOG . Lets call it 0 (full anticlockwise) to 10 (full clockwise)(scale)
Lets say the sound, style , tone is good around 5.
How do I do then to add a second pot that I will use to “fine tune” this 0 to 5 range ?
Ands specially what would be the value ?
Do I have to add this 3rdresistor ?
Thanks a lot and I hope I am a little more clear …I hope …
And yes the “vernier” on the Universal Audio 175 was acting like that :-) I use to own 2- 175 and 1- 176 ...
