Scenaria
NSI cell matching
« on: June 27, 2004, 10:06:22 PM »
sheesh...
so I finally have a process for matching up these cells
BUT
im going through a TON of them without even a close match!!!
I checked a few from some UA T4b modules... the typical ranged around 450-500ms decay time...
all of the ones im going through are averaging 100-120ms decay time...
this really sucks...
no wonder they cost so much to make.. im only getting like 1 out of 30 as a close match
Mark Burnley
NSI cell matching
« Reply #1 on: June 28, 2004, 05:17:30 AM »
Wow,
That's a low hit rate  :?
What vintage are the UA modules, and how many of the UA variants have you tried?
Do you think this is the sort of margin they got originally from a batch of cells, or have you got a particularly "fast" batch? I wonder how much this average varies. Also, I wonder if "advances" in component QC weedle out these "slow" cells at the factory where the cells are actually made- the reasoning being that these cells with a longer decay time are just too sluggish for industrial measurement/control purposes. And all the slower ones you want get put in the dumpster  :evil:
Might be worth finding out?
Mark
O_O tape is life O_O
CJ
NSI cell matching
« Reply #2 on: June 28, 2004, 11:00:50 PM »
err, whats your test setup like?
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
Scenaria
NSI cell matching
« Reply #3 on: June 28, 2004, 11:06:32 PM »
my fault...
I had something set to the wrong setting :) as in I was using the neg edge of a pulse instead of the pos
Last post February 27, 2005, 05:25:52 PM
by Scodiddly
Last post April 24, 2008, 12:56:30 AM
by Svart
Last post May 09, 2009, 10:31:37 AM
by Bluzzi
Last post December 11, 2009, 02:49:39 PM
by jdiamantis
