altfidelity
has anyone encountered a prefab metal chassis enclosure approximately 1/3 of the width, 2U case enclosure, or somewhere around it?
Think UA 610 Solo size, or the brick preamp, something roughly the same format.
Max dimensions would be 150mm width, 110mm height, with no depth limitation.
I have a strange format device in my rack, which consequently has left an awkward empty hole I am trying to fill with a new project.
So far I've found only this.
https://si.farnell.com/hammond/1456nek4whbu/enclosure-instrument-alum-beige/dp/2912757
But it is quite shallow, I would prefer it to be a bit deeper, at least 350mm...
Cheers!
Cheers!
