scott2000
sexy.....
Is that green/yellow wire off the hum pot helping??? where is it going??
Tubetec said:Oh yes forgot to mention , I found with single ended EL84 ,triode connected around 220volts at the anode was the max, early 30's ma current , I think the screen grid seemed to draw a disproportionate amount of current if I pushed the voltage much higher than 220v without a current limiting resistor in series. Going 250 or 270 volts in triode on the EL84 does nothing for your sound , and I tested that out with both transformer and resistor load
What I found also was, once I had 'brute forced' out Ht hum , now Lt hum became the dominant factor ,then induced hum in the output transformer ,grid to ground .
A picture might give some clues as to improvements to layout , at some point in your quest for 'pure resistance noise' in your outputs , mains Tx will become the limiting factor , you could consider housing mains tx , rect ,first filter or more seperately ,
Methodically working your way down through the various sources of noise is great fun ,Ive never used anything buy my ears as the judge , but the benefits of REW are obvious
ruffrecords said:Your focus should be first on determining where the hum gets in. Several of us have suggested the last stage as the most likely candidate but you need to confirm this by testing before setting of on the redesign trail. As I suggested before, short the output tube grid to ground and measure the hum level. If it is largely unchanged then the output stage is where you need to concentrate.
Even then, you still do not know for sure if the hum gets in through the HT or induced in the output transformer. So your next test should be to disconnect the op transformer and replace it with an equivalent resistor and measure the hum at the output again. If it goes down somewhat then you have an induction problem. If it is unchanged it is the HT supply.
Divide and conquer.
Tubetec said:When I said raising the voltage did nothing , it didnt change anything soundwise really , appart from seeming to raise hum in general ,and draw more current through the tube .
untune said:I'm tempted (depending on what the grid short reveals) to add another RC stage just to see what effect it has - is there an ideal place to put another stage, and can anyone suggest a resistor value? I have another 47uF left over but how I calculated the dropping values last time has just gone from my mind!
untune said:I had considered changing the value of that reservoir cap but I read conflicting info about the 6x4 all the time -some datasheets say 10uF, some say 20uF, others say 40uF. I don't want to negatively affect the lifespan or potentially damage anything. I could put another 22uF in parallel with it, or swap it out for a 47uF but I worry that'd be going too high.
untune said:PRR's calculations are incredbly useful and I could lose the choke but then, I wonder how that would impact the overall sound.
That's one of the advantages of the full bridge rectifier, compared with the center-tapped secondary arrangement, where the anodes see twice the secondary voltage.Tubetec said:I also see each 6x4 handles the full ac voltage across the transformer at each of its anodes
How would you do that? One option is to have a custom transformer feeding separate rectifiers that would be placed in series. Moot in consideration of the fact the 6x4 can withstand 1250Vac.,would it be better if each tube carried either the upper or lower part of the waveform and so have reduced ac voltage to handle ?
No need for a center-tapped heater, but you need a connection between the heaters and the cathodes.Could a centretapped heater supply with the tap referenced to the cathodes after the resistance work better here?
