eki1988
Member
- Joined
- Jun 12, 2023
- Messages
- 17
Have no idea of current, but ht voltage is 370v.What is the voltage/current rating of this xfmr?
Typically, non-CT secondaries are used with a bridge rectifier.
I think it should work, as it is bugera 1960 PTYou need a bridge rectifier .
Its possible with the original Marshall layout to reconfigure the diodes into a bridge on the turret board .
Most certainly do check the transformer specs and make sure its right for the job ,as Abbey says .
Look carefully , the CT connection goes to the O/P transformer primary , it looks like that board is indeed configured for a non centre tapped winding with a bridge rectifier.
Right you are! There is already a diode bridge. So it should work without that center tap.You need a bridge rectifier .
Does it mean the original arrangement is that? It would indeed take care of balancing capacitor voltage.Don't forget to add 2 resistors to first 2 filter caps (where the CT would go)
Resistor divider? To ground? What size would that need to be?Two large electrolytic caps in series require a resistor divider to balance the voltages .
It can also act as a bleed resistor ,so the caps gradually discharge when the amp is powered down .
it doesnt waste much power when the equipment is energised , but it can help prevent you geting a nasty shock if your poking around inside the chassis later .
Its case #2 Abbey , but two 100uf caps are run in series,
Typically, one resistor -68 to 220k/2 to 5W -across each capacitor.Resistor divider? To ground? What size would that need to be?
Why not directly to the pot from the "IN"? Not sure what the point of taking the signal from the Cathode is. Is this for a parallel loop?View attachment 114037
So quick question, does this wiring seem legit to you?
Yes, it would be a lot easier to see the entire schematic and know where this is in the circuit and how it's supposed to function!I see no reason to use a pot ,it needlessly loads down everything .
If you show the schematic instead of the build diagram its easier to see at a glance whats happening.
