couple of my 1290's output's have different frequency respond at same gain settings...
i set them matched at 1khz on both CH... then
if i send higher frequency ( say 7khz sine ) to both: ch_A is higher than ch_B,
if i send lower frequency ( say 300hz sine) to both: ch_A is lower than ch_B
should i need to match output 2N transistors, or
match all transistor as close as possible....
i use choke connected to trx for balanced output...
