Does anyone foresee an issue controlling a relay using 12.6vdc heater voltage that is also elevated to around 70vdc?
I never thought about it before, but DC Voltage means a potential difference between two points. If one of these reference points is globally higher than another third reference potential, the relay doesn't care as long as its max. voltage is not exceeded, right?Does anyone foresee an issue controlling a relay using 12.6vdc heater voltage that is also elevated to around 70vdc?
I have done it before without any problems.Does anyone foresee an issue controlling a relay using 12.6vdc heater voltage that is also elevated to around 70vdc?
