130V Phantom Power
owel
Nashville, USA
What's the whole deal with 130V phantom power?
What's the current requirements for 130V phantom power mics?
Are they the same with 48V pp? i.e. 10mA max?  -- then, that would be 1.3Amps???
or is it lower?
Thanks for any info.
The only 130 volt mic power I know of is the B&K (DPA) system used on the 4003, 4006, etc. which is sometimes called 130 volt phantom power. It's actually a separate DC line from the signal line so technically not "phantom" power. DC and signal share a common return, and the mics draw about 4mA.
Michael
Michael
So it's not using a 3-pin XLR?
It's a 4 pin xlr connected as shown in page 5 of the user manual:
http://www.dpamicrophones.com/sitecore/shell/Controls/Rich%20Text%20Editor/~/media/PDF/Download/Users%20Manuals/UM%204003%20%204006.pdf
These mics require a special input circuit and are not compatible with the typical 1000-1600 ohm balanced mic input.
Michael
That looks a lot like a B&K measurement mike I once had. >100V DC to the head for polarization and to power a buffer, NOT Phantom, unbalanced back to the power-box. Interface out of powerbox could be anything; mine was a simple unbalanced output suitable for small-lab use.
The 4003 has a pre-polarized (electret) capsule and uses the +130V to power the buffer.
The output is unbalanced (that is, single ended) and rides on ~62V DC wrt. the ground pin (measured on one mic)
Maximum signal at clipping is ~+34 dBu
Michael
----From the user manual------
Output impedance:
4003 and 4006: <75 Ohm
Cable drive capability:
4003: From microphone to HMA5000: Up to 20 m (66ft)
Polarity:
4003: Positively increasing sound pressure produces positive-going voltage at pin 4.
Pin 1: Ground, Pin 2: Not used, Pin 3: 130 V DC preamplifier supply, Pin 4: Signal. (See Fig. 1)
