130V PS for DPA mics....
DrFrankencopter
Ottawa, Canada
Okay, so I have a couple of DPA 4003 mics (actually my work has 'em) that require 130V polarization. We have a Millenia HV3 preamp to use them with, but if I want to try these suckers out with any other preamp I need to get get 130V into them somehow.
Does anyone have any hints for starting on a PS design for a 130V source. Should be fairly wasy since the DPA's are directly powered on one of the pins (i.e. don't need to capacitively couple the signal through). I figure maybe a voltage quadroupler and a small power transformer would do it (any small 24V torroidal transformers out there). I only need 6ma per channel (looking to do 2 channels).
How about voltage regulators, any good high voltage regulator ICs? I figure a 317 isn't going to like running at 130V.
Kris
two transformers like 120 to 12 and 12 to 120 might be the easy way. Then a full wave bridge to two RCs and a zener shunt setup might work well (2 60Vs and a 9.1V zener might be close)
How does the Millenia HV3 preamp produce the 130V?
You could even use an LM317HV, if you add some zeners for protection.
Best regards,
Mikkel C. Simonsen
Jakob,
The HV phantom is on 1 seperate pin, as the DPA high voltage mics all have unbalanced output. There is no capacative, or transformer coupling required for the HV PSUP. But, I think that having a current limiting resistor is a good idea. To limit current disipation to around 10ma we'd need a 13k resistor in series.
Since it's applied on 1 pin to an unbalanced mic output I think that having a low ripple is very important for this Psup, as there's no common mode rejection of the preamp to help out in cancelling out ripple.
K
[quote author="DrFrankencopter"]Okay, so I have a couple of DPA 4003 mics (actually my work has 'em) that require 130V polarization. We have a Millenia HV3 preamp to use them with, but if I want to try these suckers out with any other preamp I need to get get 130V into them somehow.
[/quote]
I am wondering the same thing as I have the same setup currently but I am not inclined for DIY projects.
Is there anyone out there who would be willing to build such a power supply for me?
I am willing to pay any reasonable amount for it. I live in New York City.
Thank you so much,
The schematic has a bit of energy stored for something like a microphone.
I would add resistor after the bridge and before the first cap. Seems to help a lot with diode noise by reducing the peak current part of the diodes conduction.
You need a low current fuse at the 130VDC end. You would need the current draw and if possable use a current clamp to see the turn on surge current caused by pluging the microphone into a powered up supply to help select the correct fuse. I would use a fuse for each microphone 4 pin XLR power pin.
In the USA you can find 115 to 115 transformers if you look a bit.
Another thing use a led and resistor to preload the reg to 10 or more ma. this helps a series reg to act a little like a shunt reg. Think about it. Series regs can only supply a load. The first I read about this trick was the old TAA late 70s early 80s IIRC.
[quote author="Gus"]
Another thing use a led and resistor to preload the reg to 10 or more ma. this helps a series reg to act a little like a shunt reg. Think about it. Series regs can only supply a load. The first I read about this trick was the old TAA late 70s early 80s IIRC.[/quote]
right! for a low source you´d need some load. you could also load the output with a 100k resistor.
hmmmmmmmm...maybe a tl783 is a bad choice for a mic supply anyhow...
maybe you can build one for this guy too....
http://www.groupdiy.com/index.php?topic=15272
Hey all,
Does anyone have a schemo for the DPA psu/preamp? Namely the HMA 4000/5000 but I would be happy with any 130v condenser psu schematic. Any help would be REALLY appreciated.  8)
