1H and 100mH single inductors
I was able to get 100mH on a Mullard FX2240 pot core with 0.3mm magnet wire ,
the insulation was damaged as i wound it though ,so I suspect a few shorted turns ,
measures around 3 ohms dc ,
I have some 0.1 mm wire that might get me in the right ball park .
Mostly you see a brass screw securing the pot cores , I was wondering how the core properties might vary using different materials like iron or nylon screws to secure the assembly .
An iron core might have a more forgiving overload at low audio frequencies , ferrite seems generally only reccomended down to 1khz ,
The exciting thing about making inductors is you can exercise control over the alchemy to create something more than just the sum of it parts ,
I was hunting around for a filter calculator for audio , where all the rellevent factors have an input field , that only gets you so far though , it tells you nothing about how your filter sounds under real world conditions .
I can confirm the 1H Mesa inductors work well in the few circuits I've tried them. The last ones measured about 600 ohms. For $5 they are a steal.
Thanks !!! I’ll give them a try then :)
Edit : arg, shipping is a real downer… 57USD to France 😵
I've always assumed that these Xicon worked okay at instrument level for very small DIs, wah inductors and such, but would saturate on line levels due to their poor / small build ?
That is always a concern but first we need to know if the inductors actually see anything like line level in the EQ circuit. I am not familiar circuit being discussed but if the inductor is in a negative feedback loop the levels it is exposed to could be very small.
Many of these small transformers are a lot better than their spec would lead you to believe. The specified transformer is a 10K:10K type according to the Mouser data sheet. I have used a Triad 10K:10K transformer of very similar dimensions o provide a balanced floating input to a VU meter buffer. Distortion is not much of an issue in this application but bandwidth and saturation levels are. From my own measurements of the Triad transformer I found its response is flat up to 20KHz and it would not saturate at levels in excess of +8dBu (which is the meter pegged to the stop) at mid range frequencies. Transformer distortion/saturation in all cases is never really a problem above 100Hz. The Zicon transformers are specified for a power of 200mW which tells us very little for a 10K transformer but for a 600 ohm one it represents +32dBu.
