i have no idea re kmr pad... but
if you mean, you wanted to use mic and line level from ez1290 board, answer is yes...
one at a time tho
use original gain switch on board for mic level, and additional one for line level as i posted above...
but you need to make a selector switch for line/mic input.
so, you can use one input at a time... and remember mic level gain switch will control line level gain too.... so when you switch to line level input, you need to terminate that connection... look at the 1290 schematic... you will figure it out...
someone selling a switch for this...
from the same switch ( grayhill on a pcb with some resistors) you can control line level/off/mic level gain.....
i will post the link when i find it.... somewhere in my bookmark list...
EDIT : Glide On Fade Awesome Switch
http://www.glideonfade.com/electronics.htm
