1x4 Audio Matrix Switcher
Mrosso
Fresno, California
Anybody have any plans or ideas for a 1 input-4 output matrix switcher? I want to take one mic input and switch it between four different outputs. Can I simply wire in up to a 3-pole, 4 position switch? Are there physicsie things I need to worry about, or is it a simple point-to-point?
Mario
[quote author="Mrosso"]Can I simply wire in up to a 3-pole, 4 position switch?[/quote]
Yes. A good rotary switch will do the trick fine, but better make it really good - don't use a Lorlin type switch here.
Simple point-to-point is fine too. Use a good, shielded box.. and if you want to go fancy, use shielded cable inside.
:thumb:
You don't want to switch pin 1/shield. Pin 1 at each I/O XLR should tie directly to the chassis via the shortest possible piece of wire.
For best results, use an 8 pole, 4 position switch. Each output gets two poles (one for each signal line), and is wired so that the output jack is shorted between pins 2 and 3 when NOT in use.
Bri
Thanks guys,
That is great information and just what I needed to know. Does anyone out there have drawings/plans for such a device? What make of switch would work the best here?
Mario
[quote author="Brian Roth"]You don't want to switch pin 1/shield. Pin 1 at each I/O XLR should tie directly to the chassis via the shortest possible piece of wire.
Bri[/quote]
I scratched my head on this description but I got it now? :green:
Thanks :thumb:
