Soundcraft 800b, apparently modded
Off75
Member
Netherlands
Hi all,
I've recently acquired a Soundcraft 800b (24x8) for very cheap. I used to have a 200b that I liked (that was a long time ago)
It seems to work well apart from some sticky pots (all lights, leds work, Vu meters react well to the oscillator).
Unfortunately, I couldn't test it properly because this mixer only has XLR Male connectors on the back instead of female (for the mic inputs...)
I'm wondering what those are for? what output could that be? Direct out maybe?
It also has 2 big Socaplex 37 male connectors (1-12, 13-24) so I assume those are for the mic inputs? If so, it's not good news as those cables/stagebox are pretty expensive!
On the other hand, I've checked the 8017 modules and they all have a Sowter transformer on it which I didn't expect!
It also has a funny Aux mod where each of the 24 channels has 4 switches for pre/post sends. Then there's a channel where there are 2 sets of 8 switches that allow to route the sends (I guess?) to the groups, Auxs or LR mix...
Finally, it has 8x 8016 modules with a "Sends Matrix" that I haven't yet understood what its purpose is. It seems to be designed for live applications, but without audio going through it, it's hard to understand from the manual.
If anyone has a clue or tips, please let me know!
    1.6 MB
    1.9 MB
    2.8 MB
The reverse gender inputs are sometimes used in location recording or other film related stuff. Or as suggested above, set up maybe for live recording or as a monitor desk. Whatever the reason, if it's not useful to you as is, just change the connectors back or make up an adapter loom.
I'm thinking about getting rid of those 2 Socapex connectors (which I assume are the mic inputs), to desolder the wires and maybe use a harting connector instead that I could use with a stage box.
The XLR Male connectors are connected to those wires. I don't have the schematics but I can see it's labeled Line Out on the board so it might be related.
    2.6 MB
Also if somebody has the schematics for the 800b especially with the modules 8016 and 8017, I'll be interested to have a copy!
Thx👍
I didn't know these had sowter transformers in them..cool.. I believe there is a soundcraft user group that might be able to help?
Hi all,
It is a typical modded desk by the Dutch Broadcasting Company (NOB
Audio).
They always put xformers in the inputs.
The Socapex is used for the inputs.
They used XLR cables with on both sides an XLR male.
I have a lot of parts (potmeters and knobs) for this board!
Hi @dreamwizard
By design, this mixer is not equipped with transformers. As Tafkab mentioned, it has been added later, which was a good surprise. I haven't found the Soundcraft user group yet, but I'm still searching 🔎
Hi @tafkab2000
Thanks for your input, it's great to have some details and history on this mixer.
I have since desoldered all the wires from the 2 Socapex, removed them, and will add XLR(s) female to the back of the mixer instead.
I've made a quick test by soldering the wires from Mic 1 to an XLR and connecting a mic. it works but the signal was a bit low. With another mic, turning on phantom power generated some noises. I'll make another test with another module, but I'll probably need to double-check the grounding and recap the channels (I'm still looking for the schematics for the 8017 module :))
