> Can you suggest any models of the rectifier?
MUST be rated more than the -transformer-.
What is the raw DC voltage, about 50V total? Then a 50V rectifier is marginal. These days silicon voltage is cheap, and rectifiers are cheaper by the dozen (or 10-bag) so go wild and order enough 400V rectifiers for several projects.
Since you don't need even 1A, gyraf is generally correct. However Kev has a point: sometimes you pick a transformer that is convenient (or cheap) that happens to be "oversized" electrically. If a 2A transformer falls into the project and fits perfect, use 2A rectifier.
The 1A rectifier will work, maybe for a very long time. But at start-up the peak current is all about the transformer, not the load. If the starting surge is too high, it will start 1,000 times or 100 times and then crap-out from repeated stress. And sometimes, rectifiers crap-out dead-short, setting your transformer or line cord on fire (or blowing the fuse you should have!).
It is possible to calculate the exact theoretical surge current, but an "oversize" rectifier is cheaper than the value of your time to do the math. Go at least as high as your transformer, round-up, and look to see if the next larger Amp rating is just pennies more cost.
When I was building and rebuilding power supplies daily, I kept piles of 400V 4A rectifiers handy. Even for 20V 0.05A jobs.
