2 resistors instead of a center tapped transformer?
MicScharf
Active member
Germany
Where is my mistake? I thought instead of a transformer with a CT I could go with two resistors like I drew in the schematics in red. I used 6,8k, doesn't work, what am I doing wrong?
6.8k is the value of the phantom power buildout resistors inside the mixer... You have effectively 13k+ in series with both . That could be low current/voltage but might still work.
What voltage are you measuring at XLR pins 2,3. How about voltage measured at R7?
"Measuring at XLR pins 2,3" meant with respect to ground / relative to ground (pin 1), NOT "between pins 2 and 3"
Here I see 47k and 10M
47k to supply the JFET, yes, but that's drawing probably 500uA / 0.5mA, if even that. The C414 (P48?) circuit will probably need a bit more current than that.
Is your phantom power being supplied correctly? Is it turned on? Are you still measuring virtually 0V even inside the XLR socket of your preamp / phantom power supply? Is your mic cable 100% ok?
May be I am totally wrong - I am a total newby to anything that is solid state - but I would try connecting those resistors before DR1 and DR2 instead than after
And how would that make any difference? Well, unless DR1/2 no longer have continuity...
For what it’s worth (I have a rather limited understanding of electronics), I used two 4.3k resistors instead of R7 (just cardioid, no high pass and some other substitutions), which should give around 43 V for the capsule polarization according to my simulation. I never bothered to measure as it seems to work fine.
You might want to read this thread
https://groupdiy.com/threads/c414-eb-p48-build.75491/
Also uses ohms law to calculate voltage drops and then work out what changes besides the lower capsule voltage
I would use 2.2Ks matched better than .1% this is low enough for a lower voltage drop and not to low that it loads the circuit to much
The CT was most likely used to keep the capsule voltage up at the current the circuit operates at.
The 2.15k might need to be reduced in value
