Rather than bring back a zombie thread, figured I'd make a new one for 2024.
I have a Yamaha HS8S subwoofer. It rules and sounds great (I've been using it with NS10s), but the built-in crossover is kind of "eh." Seen photos of the built-in amps on the HSx series monitors and they are full of JRC4558s
with NS10s, who cares but with more critical speakers, you don't want your nice clean signal going through a bunch of 4558s before your amp...
Making this thread for opinions, suggestions, and ideas.
CURRENT SETUP:
OPTIONS:
CURRENT SETUP:
- XLR balanced out from converters / interface (output impedance is 150 ohms according to RME) > Yamaha HS8S XLR input > Yamaha HS8S crossover XLR out to power amplifier for nearfield monitors.
OPTIONS:
- using a Y-split XLR cable from the main outputs of the interface. Obviously you lose the ability to high-pass your main monitors in this configuration and impedance could be an issue? idk. (the HS8S sub still has a variable hi-cut / lpf on the amp though)
- transformers to split signal. Jensen has their ISO-MAX line of pre-assembled units but they're not cheap. Wouldn't be hard to wire up a little box with an off-the-shelf line xformer though.
- Passive crossover network? insertion loss?
- Active crossover options?
- some other sort of DIY crossover using better ICs than what Yamaha is using. Maybe one of Rod Elliot's projects (this is Project 09: "24 dB/Octave 2/3-Way Linkwitz-Riley Electronic Crossover" or Project 148 state variable) but using a modern opamp like an OPA1656?
- Nelson Pass' project looks cool but like, way more intense than I probably need: https://diyaudiostore.com/products/diy-biamp-6-24-crossover
- others?
- DSP products like the miniDSP Flex. With balanced connectors, this thing costs almost $600 USD and has more features than I need. I'm not really trying to do that.
- track down service manual and mod the subwoofer amp / crossover. no thanks.
