2SC3329 model - looking for
clintrubber
The Netherlands
Hello,
I thought to remember that a Spice-model for the 2SC3329 has been mentioned here, but looking around and also elsewhere didn't gave much.
Anyone got one handy ? Or a link ?
Would be much appreciated !
Peter
Models for Japanese transistors seem to be notoriously difficult to find. You might want to use models from other small signal transistors, depending on which parameter is important for your simulation. For similar hFE use a BC550C (or BC550B if you don't have the BL rank), for similar capacity/fT perhaps an oldish high-voltage part. Noise and bias needs to be verified in real world anyway if it is critical and about any other parameters should be reasonably similar to most general purpose small-signal transistors.
Samuel
Thanks Samuel for responding. OK, will use the BC550C, I have indeed the -BL taste. Googled some interesting links about what seemed to lead to more 2SC3329-stuff but today these liks seem to have become some spy crap info and nothing anymore about BJTs, too bad...
Can always hack the model to make it closer to the 2SC3329 but I haven't toyed around much in sims so far with devices with this low r_bb'... I read in your words that you've been there and that in that region simulators are not very spot on, correct ?
Regards,
Peter
I forgot to mention that you could parallel a few BC560Cs to get a closer match with respect to rbb' and capacity.
In that region simulators are not very spot on, correct?
Basically there is little reason to believe that simulation is inherently inaccurate for low-noise design. But both DC precision and noise behaviour depend heavily on ill-defined and widely variable parameters such as rbb'/hFE/Vbe and may show a dependence on difficult (not usually impossible, just tedious) to simulate parameters such as thermal effects and PSU or ground limitations.
With sufficiently accurate models you could well estimate actual production run performance with Monte Carlo simulation, but unfortunately the poor-man simulators/models we use are miles behind what would be required. My simulator shows a single "transistor tolerance" parameter, defaulted to 20%; I don't have a clue (and IRTFM) what this piece of software really does with my transistor models--but it likely won't be too close to real world deviations. IC manufacturers surely have all the data for their processes though.
In the end you have to understand both circuit and simulator yourself to estimate the validity of the results. In that particular case you mostly need to know that using higher-rbb' and -fT models may lead to unrealistic stability margins for high feedback designs.
I never used noise simulation as noise performance (within the audio band) can be pretty easily estimated by hand (read: Excel/Matlab) calculations using standard approaches--I see that you allready got a copy of the relevant book.
Samuel
Hi Samuel,
[quote author="Samuel Groner"]I forgot to mention that you could parallel a few BC560Cs to get a closer match with respect to rbb' and capacity.[/quote]
That'll help (550C). Will also see if I can hack the model to tweak for lower rbb'.
No indeed, actually I should have phrased that differently - I was more thinking about inaccurate model-parameters, like you added. Sim-results never better than the accuracy of the relevant parameters.
One of the thing I want to toy with is the influence on noise-performance of hFE- & Vbe-variations. As in: for a low-gain balanced circuit the DC-offset doesn't matter to much to me, but without getting the equations out yet, the question came up as to what would be the best property to match BJTs for: hFE or Vbe.
Equations & pencil & paper will tell more, but so far for noise-performance I'd at first vote for hFE-matching over Vbe-matching (despite it turns up as sqrt(hFE)), but a delta-Vbe will give a delta-Ic which spoils the optimum value again (hFE & Rsrc --> Ic_opt).
And can't rely on any correlation in both spreads (hFE & Vbe).
Not unlikely though the hard resulting performance figures will tell it's mostly academic, since the 'OSI-optimum' isn't too sharp, so vv for Ic.
Simply build, I might perhaps better skip the sim-phase and just measure resulting performance for a few different BJTs with known hFE & Vbe.....
Yes :grin: and no... :cry: the places to fit the parameters are all there (= the models can handle them), but unfortunately not all processes yet fully characterized once designers need to start making first designs in them. That may be temporarily for most processes (...), but in the past some CMOS-processes remained lacking w.r.t. full analog characterisation of devices (espec. for sub-threshold: models can handle that region, but no accurate parameters).
Now that we're approaching the point of CMOS with just-above zero supply voltages, about any analog sign of life could be considered compromised :wink: , so luckily the need for proper characterisation has been better recognized.
Luckily the simple stage I mentioned earlier does local feedback, no global, so that'll help here I assume for now, but otherwise indeed trouble of inacc. stability validity.
You spotted it :wink:
I think it was Brad/bcarso that I saw first mentioning it and after some more appearances it was clear this was a nice book to have :thumb:
Regards,
Peter
So...Ah...Um......
You guys gonna spill the beans on the title of this relevant book?
Or is it too much for the unwashed mass brain to comprehend and you are really doing us a favor?
Ignorant and struggling to follow along in tha' swamp - Irv
+1.. great book for low noise design.
I actually called Fitchen on the telephone when I discovered he was a college professor teaching about 15 miles from where I was living (CT). I tried to pick his brain about some obscure low noise topology I was trying to figure out.
He was pleasant on the phone, and talked about the possibility of a second edition, but AFAIK it never happened. This was 25 years ago so I suspect he's retired now.
That'll be this book then ?
C.D. Motchenbacher and F.C. Fitchen, Low-Noise Electronic Design, New York: John Wiley & Sons, 1973.
In general, it's oftern a bit confusing when authors write related books with about the same title, but as I understood it from the preface the one you mentioned (with Fitchen) is then the 1973-version of the one I have here:
"Low-Noise Electronic System Design" (with J.A. Connelly).
A bit strange the author carefully omits to mention his earlier co-author :roll:
Regards,
Pter
opps. :oops: I didn't even notice that was a different book. I did a quick google of Fitchen and I guess the similarity of the title and even look of the book, confused me.
My sense is that the Motchenbacher was a real working engineer at Honeywell for practical input, and Fitchen was the professor type to dot the I's and cross the T's.
Perhaps he hooked up with a new engineer type. Has anybody compared the two editions? In '93 I would expect a dramatically different selection of devices in the low noise circuit examples.
From reading the description the later book looks like it also investigates noise considerations with ICs, while the early book was mostly discrete designs.
[quote author="Samuel Groner"]The older book seemed more valuable to me as in the later many good examples of discrete design were omitted (IIRC). [/quote]
Additional topologies etc ? Hmm, boss paid the '93, might be interesting to see if I can find me a '73 myself.
Regards,
Peter
It's nice to have both books if money is not too tight.
JR, no, there are no new devices IIRC---the measured noise data (quite valuable and not seen anywhere else AFAIK) are the same. And then as SG points out there are some omissions of valuable material in the new book. Of course a lot of damn IC designers would have us all believe there's nothing left to be done with discretes anyway (bloody fools I say :grin: ). And the semi houses are cooperating by discontinuing the good devices. Reminds of how LP records were getting ridiculously degraded about the time that "Perfect Sound Forever" was starting the big drum beat. OK enough of ranting.
I tend to reach for the old book more often than the new.
I think the theory of what Fitchen's role in the first book was may well be correct. He has other more academic and moderately useful books to his credit I believe---I have at least one of them (EDIT I see there are at least two: ISBN 0442024029, 0442224060). Maybe an antipathy did spring up. If nothing else, editing a book like that is a royal pain and could have led to some serious stresses.
EDIT: and note that Fitchen rhymes with bitchin' :grin:
Peter,
Thanks! Amazon has a copy from the US side coming my way soon!
I must admit that low-noise design was only a footnote in my university studies. :? I have half-heartedly been trying to fill that void since then. :roll: I'll search for a reasonably priced copy of the '73 version.
Never stop trying to learn! :thumb:
Peace - Irv
[quote author="KingKai"]Peter,
Thanks! Amazon has a copy from the US side coming my way soon![/quote]
OK, so you got your book, fine, but I still don't have my 2SC3329-model :wink:
No problem, the given hints will do there, enjoy reading !
The quick search this afternoon didn't show anything yet, but that was, right, just a quick search.
Should really read the '93 more, but won't pass up a good deal on a '73.
Peter
[quote author="JohnRoberts"]My sense is that the Motchenbacher was a real working engineer at Honeywell for practical input, and Fitchen was the professor type to dot the I's and cross the T's.[/quote]
The usual absence of honour when not being the first author that is mentioned... :roll:
Of course the first author most likely the most important one, but while we may just guess the contributed work from each, we do know the 'fame' obtained with some higher accuracy: ten points for the first and for the second no points left....
[quote author="clintrubber"][quote author="JohnRoberts"]My sense is that the Motchenbacher was a real working engineer at Honeywell for practical input, and Fitchen was the professor type to dot the I's and cross the T's.[/quote]
Of course the first author most likely the most important one, but while we may just guess the contributed work from each, we do know the 'fame' obtained with some higher accuracy: ten points for the first and for the second no points left....[/quote]
I meant no disrespect while my experience with college EE professors is mixed between those who fit the stereotype and those who don't.
I think it was Cal Perkins (lately at Mackie) who said he would consider hiring a just-graduated BSEE if s/he had studied with one or both of only two professors: Barry Blesser at MIT, or Robert Meyer at Berkeley. Pretty severe :roll:
I heard this expressed in a time before the advent of Horowitz and Hill's book, which rewards serious study and reflection and could help fill out a more conventional curriculum, and before finding Dunn's Gateways to Electronics. Based on the books I would guess that those three authors might turn out to be great teachers.
Sorry---still no 2SC3329 model. If you are serious, I'd read up on Gummel-Poon, then get out datasheets for some well-known transistors and compare to the tabulations for them in Spice. Once those two are reconciled, you could take the datasheet for the 3329 and derive the G-P parameters. Let me know when you are finished so I can get the results from you :razz:
Peter[/quote]
Do a search on bookfinder.com for ISBN 0471619507.
You will see several copies, not all distinct (the usual alibris duplication at work, and other multiple listing things). Cheapest is 9.95 USD + shipping, unless someone has already snagged it. The highest price is $242.15 (!).
[quote author="bcarso"][quote author="clintrubber"]
Peter[/quote]
You will see several copies, not all distinct (the usual alibris duplication at work, and other multiple listing things). Cheapest is 9.95 USD + shipping, unless someone has already snagged it. The highest price is $242.15 (!).[/quote]
That's a no-brainer, Brad thanks for spotting ! :thumb:
Couldn't complete my order yet, but the book should be reserved for me now.
Peter
