Not capacitance but maybe input resistance of only about 30MOhm...
How do you get "30M input resistance"?
Not from the datasheet and not from the 2SK596 Datasheet.
Be careful to not infer that the datasheet equivalent schematic is real or that there is a real resistor.
It reads "equivalent circuit". The resistor is actually the parasitic current in the second diode (counting L->R) while the first diode is actually the J-Fet Junction.
So the precise internal schematic is this:
Or to infer indeed that the -1dB worst case 110Hz attenuation stated with 15pF source impedance is indicative of the input impedance (if it was, it would be ~ 500MOhm).
A lot of the Datasheet values are "limit values" that are guaranteed across all operating condition (unless stated differently in the small print). Like at elevated temperatures where electron mobility increases and parasitic diode currents increase or with very large Vds which causes increased leakage currents.
There is a reverse biased diode on the input (and the diode of J-Fet Junction). Intention is to operate the J-Fet at Idss with zero V Vgs.
These diodes provide a non-linear resistance, which up to ~ +/-0.4V is near infinity (depends on electron mobility to sure exactly how low the parasitic currents will be).
Precise measures are hard to come by, but at normal signal levels it is extremely high.
As we have a guaranteed limit of ~500MOhm for the 2SK596, we can assume "typically GOhm" fairly safely.
As the circuit starts "limiting" at ~ 0.4V Peak (or 28dB above 10mV which is ~ 94dB SPL output on most larger capsules and thus at 122dB absolute SPL) it may be desirable to "bootstrap" the input.
At the same time, the non-linear input impedance above 122dB may be desirable and if not we can always add a capacitive pad if we need higher SPL's.
And of course the J-Fet can be used with non-electret capsules, but in circuit the reverse biased diode must be accounted for.
Generally "Non ECM" J-Fets lack this diode. So the "ECM" J-Fets cannot directly drop into circuits designed for normals J-Fet's.
Thor
