Aharon
Forgive me if this is not the right place to post this but how much are you guys paying for a 2U rack box?.
What's a good price?.
Aharon
Aharon
With all due respect, you can remove the top and bottom panels WITHOUT removing the back panel. Remove several screws and the top and bottom lids slide back and come right off.you have to remove at lest the back panel to remove the top.
True but I found it to be a non issue. They are built like a tank and they are cosmetically appealing because the faceplate doesn't have extra holes for mounting to the chasis.and there are little lips that tuck under the "U" of the front panel on the top and bottom, which reduces the inside clearance by maybe 1/4". just look at the specs carefully.
They will scrape. I used screws that were flush with the bottom to avoid this.Question about the Middle Atlantic Chassis...
is the height of the sides (i.e. the height of the body of the enclosure) slightly smaller than the height of the front panel? ...The reason I ask is I'm wondering if PCB mounting screws have enough clearance so they don't scrape what ever is below when placed in the rack.
