martingriffith
Member
Just found this http://esstech.com/index.php?p=products_ADC
Svart said:When dealing with a lot of companies that make ICs, I've experienced a lot of the NDA/company name on the datasheets/password protected Acrobat documents/etc.
It's a pain in the ass but these companies think it helps somehow and I don't think they'll stop anytime soon.
There is a company that we deal with that will only talk to a single person at our site, the person whose name was on the original contract documents... talk about paranoia..
Yes, I'm so into this 32-bit ADC that I forgot about it, good to remember.There is no point in 32-bit converters in pro audio. Going from 24 bit to 32 bit is as useful as adding wings to your bycicle. It will probably hurt less, but it won't do any good. The theoretical SNR of 24 bit is already far below any reasonably attainable noise floor in the buffer stages, let alone the rest of your equipment.
The most useful function of 32 bit conversion that I have seen is the ability to recover clipped material by simply turning the audio file down in your DAW. Not possible with 24 bit conversion, it just stays clipped.There is no point in 32-bit converters in pro audio. Going from 24 bit to 32 bit is as useful as adding wings to your bycicle. It will probably hurt less, but it won't do any good. The theoretical SNR of 24 bit is already far below any reasonably attainable noise floor in the buffer stages, let alone the rest of your equipment.
Possibly in a DAW with floating point coding, but has nothing to do with converters. A signal actually clipped during conversion stays clipped.The most useful function of 32 bit conversion that I have seen is the ability to recover clipped material by simply turning the audio file down in your DAW. Not possible with 24 bit conversion, it just stays clipped.
https://mediatech.edu/32-bit-audio-end-audio-clipping/
