k brown
I was being 'arch'.I hear ya', but over here in Europe we rarely have shootings in recording studios
ask Silvia Massy and TOOLI was being 'arch'.
Just curious about practical use -maybe I'm overthinking this and I might be using the ZOOM F3 for an upcoming project. Does the interface avoid clipping during recording by scaling the gain and conversion—resulting in "auto-gain" rides? Or does the file get normalized after the record pass so that the maximum level is some predetermined level (below clipping)? Or do you import the file at 32-bit float to a DAW and then scale the gain to lower peaks below 0 dBFS? Or do you just set the input level to something like -50 dBFS and let the box do its thing and just gain up the file later? I guess I should download the ZOOM and SoundDevices user guides to get this info...I use my Zoom F3 as a field recorder for recording bat ultrasonic echolocation signals.... It's 32 bit float format is really useful when you're dealing with wild variations of signal source location , and really wide dynamic ranges that can be encountered, on occasion.
Not having to try and make gain adjustments outdoors - and in the dark! - is a really useful feature.
OK, bit of a specialised function I grant you, but 32 bit float format is really useful where you are making this kind of unpredictable nature recording... or indeed trying to record any type of highly unpredictable sound source....
That's my approach. One advantage of 32 bit float is that - unlike conventional A/D conversion - low level signals are recorded without any loss of resolution. I have found that even using a mic connected to the line input, and then increasing the gain in DAW can still give quite amazing results......... Or do you import the file at 32-bit float to a DAW and then scale the gain to lower peaks below 0 dBFS.....
That's the only advantage I see. The total available dynamic range will be set by the analog input stage. There is no way to scale that. I can see how having full 24- ish bit resolution at very low levels is a big help in field recording.One advantage of 32 bit float is that - unlike conventional A/D conversion - low level signals are recorded without any loss of resolution. I
Back in the 1990s, I recorded sound effects for a video game and I got to travel to a ranch where the owner had several vintage tanks, cannons, howitzers, and all kinds of rifles and machine guns. He didn't want to waste a lot of cannon shells so I wound up setting up something like six microphones at different distances from the gun (outdoors, of course). I recorded into three different field mixers and DAT machines to make sure I had a wide range of gain settings and pads so as not to overload the recordings. The noise floor was limited by the ambient sound of the field we were in, and the headroom by the mic capsules. We managed to get some excellent recordings—along with lots of overloaded recordings that couldn't be used. A 32-bit recorder would only improve that situation a small amount, since the environment, and not the electronics, dictated the dynamic range. For production sound on a quiet movie set, 32-bit could be set to record shouting and still sound good when capturing whispers or breaths.That's the only advantage I see. The total available dynamic range will be set by the analog input stage. There is no way to scale that. I can see how having full 24- ish bit resolution at very low levels is a big help in field recording.
Just curious - what about it needed refurbishing?I can't say anything about the newer Sound Devices products as I have not had any first-hand experience with them, but I've had a 788T for 15 years and it has been outstanding and faithful all this time. I recently sent it in for full refurbishment because I intend to use it another 15. But if I were purchasing a new recorder it would be Sound Devices. For my needs it would probably be a MixPre II.
The format (i.e. float vs PCM) will have no effect on clipping or adjusting the input signal. Some field units have what's called an autoleveler which is somewhat like a compressor in that it measures the incoming stream and creates a DCV output and that goes into a VCA to adjust the signal to best fit the ADC input capabilities. Other systems rely on the user to adjust the level going into the unit.Just curious about practical use -maybe I'm overthinking this and I might be using the ZOOM F3 for an upcoming project. Does the interface avoid clipping during recording by scaling the gain and conversion—resulting in "auto-gain" rides? Or does the file get normalized after the record pass so that the maximum level is some predetermined level (below clipping)? Or do you import the file at 32-bit float to a DAW and then scale the gain to lower peaks below 0 dBFS? Or do you just set the input level to something like -50 dBFS and let the box do its thing and just gain up the file later? I guess I should download the ZOOM and SoundDevices user guides to get this info...
