SSLtech
From the 3M M79 problem thread, I have some questions about 'fail-safe' on the M79 -I've Never had to work on the spooling motors, so I never looked at how they did the braking.
I'm curious as to how they prevent tape spill in the event of a power failure/fuse blowing/breaker popping/drunk guitarist tripping over the power cord (select as applicable) when the machine is winding. -I can see that if the motors are shorted, they'll brake just as surely as throwing a short across a generator output makes it harder to turn, but lets say that at the moment of failure, the circumstances are as follows:
The left reel is near-empty (we just played to the end of the tape) and we've just hit rewind about 10 seconds ago. -The machine has wound itself up over ten seconds and has now reached maximum rewind speed. -Then the power suddenly goes out, and the relays short across the motors, providing an (as I see it) equal braking force to each reel motor.
The two motors will not slow down at the same rate if they don't have the same tape load. -In this example the reel with nearly all of the tape on it will take rather longer to slow down and reach a full stop. -Not only is 2" tape reasonably heavy but a significant portion of it is further from the center than most of the motor mass, and so travels faster and has proportionally more inertia per unit mass.
Stop me if I'm missing anything. -There's possibly something clever and subtle that I'm overlooking!
The lighter left-hand spool should stop more quickly, thereby ceasing to 'take up the slack' -literally- which is being fed to it by the right hand spool (when rewinding). -Since the right hand spool will take longer to slow down and stop, it would continue to provide tape, thereby 'throwing a loop'.
Brake bands are usually designed so that they provide more resistance to rotation in one direction than the other. (Turning in one direction tightens the brake band against it's anchored end, turning the other pushes the brake band towards its anchored end thereby slackening the tension on the brake band.) By arranging this so that both reels are fighting more resistance while they are turning in whichever direction 'pays off' tape towards the other spool (i.e. the right hand -takeup- reel is tighter when turning clockwise, the left hand -supply- reel is tighter turning counter-clockwise) you can ensure that the tape will always be braked by the "supplying" spool no matter which direction the tape is moving when the power fails.
Some simpler and cheaper machine designs (ReVoxes leap to mind as a classic example) use the brake bands to stop the tape at all times, not just power failure. -Pressing "stop" removes motor power and puts on the brake bands. A much more elegant method is to apply the opposite wind command until the tape is almost stopped, then press the stop button. -Other designs (MCIs JH-110 and the Otari MTR-90 for example) use the brake bands only when the power is removed, or there is no tape loaded on the machine. In the case of the MCI this means that in the stop condidion the tape is almost always creeping very slightly in one direction or another, which is infuriating at best and leads to accidentally recording over the tail end of a mix at worst. (ask me how I know!!! :shock: )
So I guess the question is: Under the above mentioned circumstance, does the M79 throw a tape loop when the power fails suddenly -and when there is an unfavourable distribution of tape between the two spools, or is there something I'm missing. -Since I've never had to look at the reel motors, I've alwasy asumed that they had brake bands, but if that's not the case, I'm puzzled as to how they protect the tape. As I currently understand it, the "short-circuit" braking doesn't provide as good a protection as the brake band alternative.
Keith
Keith
