The opamps can be the two halves of an OPA2132 or an LT1469. If you want to drive a 5k or greater balanced load, either will work; if you want to drive a 600 ohm load, probably you'd be better off with the LT1469.
This works as long as you can promise that Pin 3 will never be shorted to ground -- for example, by an improper XLR-1/4" adapter cable. With that one proviso, this will be an excellent converter circuit.
